Exhaust question!!!!!!!
Hi guys, I try to do some searching but didn't really find what I was looking for!
I have a 2007 GS Sedan that I'm wondering if I should go HFC's or just get down pipes(eliminating the cats all together) had gutted cats on my VQ35 equipt Maxima and she loved it,but I noticed some low end loss of tq,so I want to hear from personal experience what is you guys experience with mentioned mods on this car.Thanks again guys.
I don't know if this is also true for 2007-8 G35 but with 2009 and later, the reason they make more noise at cold start up is ECM richens mixture initially for 6-7 seconds to send unburnt fuel into catalytic converters where it then burns, to get cats up to operating temperature quicker to reduce emmissions quicker. So if you delete catlayst and run test pipes resonated or not and ECM is still programmed to dump extra fuel in at cold start to heat cats, which are no longer there, this could be the source of the gas smell you notice when cats are deleted.
I have searched to find pedal ECU reset method but could not find it. I checked DIY section... What is process to reset? If there is thread or post with this info, let me know where, Thank you.
