ZEX Wet kit on high-miled VQ...?
I really don't want this to be a hate thread, but i have a serious question. i have a 2005 G35 6MT coupe with 136,XXX miles on the clock, and ive owned the car for three years. I have replaced the oil every 3K yada yada yada, all synth, and stuff, but i was curious to see if people think this is too high miled for a Nitrous Kit. i am ONLY looking for a 55 shot, and am well aware if the kit were to be installed, i would need a proper tuning, (including, but not limited to) colder plugs, 2 degrees retarded timing, and a tune.
just want honest opinions, and some information if any of you guys have had the "bottle" on a high miled motor.
P.S. first thing im doing is getting a compression test to see how healthy the engine is. i just wan some reassurance.
You have the correct approach, compression test will determine wear for mileage.
Assuming compression good, all the above precautions mentioned in first post will ensure safe use of nitrous.
Suggest bottle heater, window switch, fuel pump upgrade, and fuel pressure switch.
Never used on high mileage engine but have used it for 30+ years on four different vehicles including My G.
sman217 (09-03-2014)
Thanks so much for the response, HotRodG35; it's good to hear back from one of the nearly 100 viewers of this thread! But again, thanks for clearing up my concerns... I just wanted to check, is the fuel pump upgrade really necessary? I'm not doubting you in ANY way, I just want to make sure i have all the required gear to maintain maximum reliability. The nitrous kit wont be being used much, just at an old airport in Kentucky that we all do roll races on, (completely legal, sanctioned event) again, thanks.
I talked to ZEX, and a bunch of garages across the country, asking them specifics about what i should do to maintain reliability, and such. I do have one other question... All the people i talked to recommended colder plugs, (one step colder, copper ngk's) and also a -2 retarded timing. My concern is, how much decreased power/MPG/reliability will the plugs and retarding do to the engine when I'm NOT spraying...? this isnt going to hurt my engine will it? I mean, I wouldn't think it would, because usually advancing the timing is what gets you in trouble...
Colder plugs will not affect mileage, its done because of the enviroment exposed to while injecting nitrous. I run 3 heat ranges colder myself because of boost and compression ratio. Heat range is based on how electrode is insulated and carries heat away.
Timing retard will affect performance, alternative is using engine management system with multiple MAPS such as UpREV, UTEC or for overkill Haltech. You can select nitrous MAP to retard timing as needed.
Urbanengineer (09-04-2014)
As for the rest of us, we are just curious.
Personally, it would be a toss up to put such a kit on mine, I would worry too much.
BTW I have 125K on mine.
I have everything and the nx i used on my last two cars. I have seen on different forums that the fuel pumps we have and injectors are good for up to a 150 shot on fuel such as c16 (race fuel) which is all i ran in my last car on the track. I have the access port and getting everything tuned in the spring i will post the results then. I noticed on the last car stock headers pulled a lot harder with the bottle than the aftermarket dc's.
Mad A
Not G35 Related
12-08-2015 01:45 PM
JG_G35
Engine - Intake/Fuel
09-07-2015 09:35 PM
