G37 Coupe V36 2008+ Discussion about the G37 Coupe
*Help* Dash Rattle with *With Video*
Old 05-08-2014, 10:00 AM
chrisg37's Avatar
Hi I have been trying to sort out this dash rattle for quite some time now with no luck. Has anyone had a similar issue as in my video?
https://www.youtube.com/watch?v=cqwG...ature=youtu.be
- I have tried removing the cowl and wipers (the cowl is a common problem)
- Removed the centre speaker and poked around to see if anything is lose or ratling
- Removed the two top vents up by the windshield.
Pushing on the dash or wedging anything between the glass and dash does not do anything.
It sounds like it is coming from the centre of the dash about 1 inch below.
Attached is a video. The car is out of warranty, I brought it to the dealership last week and they could n't resolve it.
Any help is greatly appreciated.
Old 05-12-2014, 11:55 PM
infinitidude's Avatar
I know this sounds really stupid but we have run into this a bunch at my dealer and it was the battery hold down not being fastened down tight enough. Sounded like it was coming from right out of the dash. Hope this helps bro.
Urbanengineer (05-20-2014)
Old 05-20-2014, 10:18 AM
chrisg37's Avatar
Thanks!
It was the battery tie down! The battery was slightly loose and would squeak over bumps. subsequently the vent intake is right by the battery and this is why you would hear the noise by the top vents.
Thanks again Jason!
The following 2 users liked this post by chrisg37:
infinitidude (08-13-2014), Urbanengineer (05-20-2014)
Old 05-20-2014, 12:56 PM
Urbanengineer's Avatar
Received 1,016 Likes on 935 Posts
It was the battery tie down! The battery was slightly loose and would squeak over bumps. subsequently the vent intake is right by the battery and this is why you would hear the noise by the top vents. Thanks again Jason!
I don't have tie downs and use a bungee cord (redneck moment). I really should buy those. Where'd you end up buying the tie downs?
Old 05-30-2014, 11:08 AM
Finnkc's Avatar
Start happening last week on the G35 ... I am going to check it tonight. I was ready to take the whole dash off to find it lol.
wonderizm
09-24-2015 03:09 AM
kinetek
08-03-2015 04:25 PM
itztwinki3
Interior
08-01-2015 01:56 PM
Quick Reply: *Help* Dash Rattle with *With Video*
