MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > General Tech Questions
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 12-31-2007, 10:58 AM
OEM alarm...is it standard?
Is the OEM alarm standard? If so, how do you activate it?
__________________
DG 6MT Coupe- popCharger, Z-tube, MREV2, Motordyne 5/16 spacer, Stillen CAT-back, Clear markers, Zaino, Fat tires, Custom MTX stereo system
Old 12-31-2007, 11:13 AM
Callaway's Avatar
I am McLovin
Standard. It's activated when you lock the car.
__________________
G37S - Journey - Premium- Sport - Nav - Tech - Spoiler
Old 12-31-2007, 11:57 AM
^ +1
I dont get the OP. Sounds rhetorical!
Old 12-31-2007, 12:48 PM
I wouldn't even call it an alarm system. It's more of a remote door opener. If you wanted it to do more, install an aftermarket shock sensor to the system.
Old 12-31-2007, 12:59 PM
Yeah... what LjN said... it's not an alarm. It just makes the horn beep and lights flash if someone manually opens the door from inside the vehicle with no key in the ignition after it has been locked via keyfob(for example... if you reach in through an open window and unlock the door and jump in the car, it will make noise). Supposedly it also does this if you were to open the hood with the car locked, but I have never tested that.
There is a cheap mod you can do where you can install a shock sensor under the hood that will make the system into more of an Alarm.
The OEM Theft Deterrent system, in its factory form, will not make any noise if someone comes up to your car and smashes a window in, then grabs something off the seat, kicks a huge dent in the side of the car out of spite, or if someone tries to tow it up onto a flatbed and pull it away.. provided that they don't try to open the door.
To answer your question, that OEM theft deterrent system is activated whenever you click the LOCK button on your keyfob.
To try it out, go roll one of your windows down... then, with the car off, shut the doors and lock the car with the keyfob. Then reach in from the outside through the window and unlock and open the door with your hand... it will trigger the "Alarm".
__________________
2004 Infiniti G35 Coupe 6MT Diamond Graphite, Navigation, Aero, Premium, Brembos w/Project Mu B-Force Pads, Splash Guards, Aluminum Pedals, Z-Tube and K&N Air Filter, 3/8" Motordyne Spacer 2001 Toyota Tacoma Stepside SR5 5-Speed 4X4 Bridgestone Dueler AT Revo 275/70/16's, Sliders, Tonneau, Bedliner
Old 12-31-2007, 03:46 PM
Callaway's Avatar
I am McLovin
Quote:
+10000
__________________
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
