MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > General Tech Questions
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 01-13-2008, 04:09 PM
how well can g35c take curves at high speed?
well, i was driving on the highway and took a curve at about 80mph and my car detected slip and traction control kicked in. i dont think the curve was that bad because i've driven that highway almost everyday but don't always drive at 80mph. i did take that same curve going about the same speed with my 06 TSX before and the TSX didn't detect any slip nor did the traction control kicked in. currently i have the stock Michelin tires in front and brand new Yokohama all-season in the rears.
Old 01-13-2008, 04:13 PM
turn vdc off.........................................
G35DRIVER.COM SPONSOR
The problem might the the different compounds used on the tires. I've gone through some curves at 110 + and had no traction problems or slipping, I would say that the coupe takes curves like a champ, it's very forgiving.
Maybe the Yoks since they are all season don't have as good grip as the Michelin tires and that is what the car is detecting.
Good luck!
Old 01-13-2008, 04:14 PM
Quote:
That would work too
Old 01-13-2008, 04:18 PM
dont turn off VDC if your slipping on the highway you need VDC to save your ***. Its most probably the different treads on your front and rears messing with your traction
Old 01-13-2008, 04:22 PM
The curves are something the G could handle with no problems... The straights is another story.
I have RAS so the curves are FUN. No slipping at all.. Unless its raining season..
Old 01-13-2008, 04:28 PM
what about sways...
__________________
Obsidian Black // SPC // Fujita // Tanabe // Falken // --just another detailing newb..
Old 01-13-2008, 04:57 PM
Nismo G's Avatar
Bradenton, Fl
I wish i could show everyone the turns at my house...but i took them at 80mph with my stock suspension while not slipping. These are pretty sharp 45 degree s-turns.
-Sean
__________________
2003 OB 5AT G35 coupe -|- Apexi S-AFC II -|-Injen CAI -|- Motordyne 5/16" Spacer -|- Stillen Dual Cat-Back -|- Stillen Engine Damper -|- Tein CS coilovers -|- Tein EDFC -|- 19" Volk TE37 -|- 1/4 mile = 13.86 at 100.4 (no damper or suspension) -|-
Old 01-13-2008, 06:15 PM
Quote:
+1 When you are driving & taking curves at high speeds you want the VDC on.
__________________
Stillen Intake W/Z Tube-Stillen Damper-Fast Intension Exhaust-Clear Corners-Tint
Old 01-13-2008, 07:26 PM
I think it might have a bit to do with the traction control systems of the 2 cars too.... The Acura system is incredibly nonintrusive on the TSX(my best friend used to have one for 2 years, and just recently traded it for an STI). Anytime I've driven that TSX or riden in it, the system will kick in if you have wheelspin, but it doesn't kill all the power.. it just seems to limit power. In our G35's, when wheelslip/spin is detected, the system seems to go heavily into the corrective action... meaning either killing almost all power to the drive wheels or heavily applying braking to certain wheels.
It's just something that really stood out to me in my experience with the TSX.
__________________
2004 Infiniti G35 Coupe 6MT Diamond Graphite, Navigation, Aero, Premium, Brembos w/Project Mu B-Force Pads, Splash Guards, Aluminum Pedals, Z-Tube and K&N Air Filter, 3/8" Motordyne Spacer 2001 Toyota Tacoma Stepside SR5 5-Speed 4X4 Bridgestone Dueler AT Revo 275/70/16's, Sliders, Tonneau, Bedliner
Old 01-13-2008, 08:10 PM
had same happen to me on my stock michelins.....now running 245 front 275 rear and hasnt kicked in.
Old 01-13-2008, 09:42 PM
Ive never had much of a problem with that. But then again i probably dont drive AS fast as you do.
__________________
05 BS coupe -- HKS HI-Power Ti . PIAA SuperRozza 20x9 20x10 . Yokohama Advan Sports 255/30/20 285/30/20 . BC Racing Coilovers . SPC Rear . 06 Projectors . USA-SPEC PA11-NIS Ipod Integration . JDM Clear Corners
Old 01-13-2008, 09:45 PM
It was probably your all season tires. Are they new? An all season will never perform as well as a full time summer or winter tire. When you're running Michelins in the front and all seasons in the rear, the rears will probably break loose alot sooner than the front while inducing the slip. Personally, I will never use all seasons again.
Old 01-13-2008, 11:34 PM
Quote:
there's your problem.
you should have stuck with oem michelins in rear... or even better, went michelin ps2 f/r
__________________
http://www.streetseen.vi || 2004.5 G35C 6MT || Volk - Michelin - HKS - Stillen - Alpine - JL
Old 01-14-2008, 01:36 AM
Why? What about regular Michelin Pilot Sports? Which one is better?
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
