MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > General Tech Questions
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 06-13-2008, 08:28 PM
Question Richie FSB + OEM Alarm = Headache
I'm curious to know if anyone has had this issue, and if so, what was done to resolve it.
Early last year I got on a group buy for the Richie front strut bar and installed it about a month or so later. Then late last year my car alarm started going off at random intervals. It's been to the stealership several times for them to repair it and after about 5 complaints and 4 trips they finally ran some diagnositic that pointed to the hood sensor switch. I get a call today and they say the Richie SB is the cause becasue it makes the hood bulge.
So it's taken several months and multiple trips for the jack offs at the dealership to say that "it's your fault for having that bar on there." Even though it's been on there for about a year.
I'm asking for help because I know a lot of people use this bar and haven't really seen anyone complain about it (at least not in this way).
Any advice/info would be appreciated.
Parting note.... If you're interested it's the Jim Coleman Stealership in Bethesda Maryland.... and no, I won't be going back to them for anything else. I've had nothing but problems with them and their dis-service.
__________________
Old 06-13-2008, 08:35 PM
redlude97's Avatar
Post-Virgin
sounds like the hood pin isnt being completely depressed causing the intermittent alarms. You should be able to move the bracket up slightly, or dremel the fsb mounts so it sits lower
__________________
06 6mt Diamond Graphite G35 Coupe
-The beauty of online forums is that you can always get the answer you want to hear regardless of their qualifications
Old 06-13-2008, 09:48 PM
I'll loosen it up and see if I can't do that. Otherwise I'll uninstall it and give that dremel remedy a try... unless someone has a better idea.
__________________
Old 09-05-2008, 02:45 AM
anyone else experiencing a similar issue?
was considering getting a stb...
Old 09-05-2008, 04:41 AM
hyperlite21's Avatar
<---She Took All My Money
i didnt have the problem with the alarm but it was rubbing on my hood for a while till i took the dremmel to the brackets
__________________
HKS-CRAWFORD-TEIN-MOTORDYNE-NRG-JWT-UTR-GIALLA-RICHIE-SxExCx-STILLEN-AXIS-FALKEN-06'PROJECTORS-PITHON-NISMO
www.myspace.com/mikeyfranco
*Team OCG's*
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
