Thread Tools | Search this Thread | Rate Thread | Display Modes |
Splash Guard Help
Guys,
I bought some front and rear splash guards from a vendor on the site. I did the install myself with no problems. Both fronts and one rear turned out great. However, the rear passenger side is not exactly "flush" with the car. There is about a 6-8 inch portion that did not really seal flush to the bumper. I rolled it and burnished it just like the others with no avail. You can barely notice it unless you walk right up on it, but it's just annoying knowing it's there. I don't know if the adhesive strip was defective or what. So instead of buying a new splash guard, does anyone know where I can purchase a strand of this adhesive strip? I don't want to use double sided tape, I want to use something similar to what was on the splash guard. Any and all help would be greatly appreciated. Thanks guys.
__________________
'06 LP Coupe 6MT | Volk | Toyo | Eibach Sportlines | Tokico | SPC | HKS | Project Kics | LLumar 20% | JDM Clear Corners | PIAA | Debadged | Rebadged |
No pics yet. However, the part is very insignificant and you could probably only fit a sheet of paper in the "gap" but nothing thicker than a sheet of paper. it's ok how it is now, but just curious where i could find a piece of adhesive strip just like the one that is on the splash guard. if i got a piece of that, i'd just take out the screws and bolts, pry back the splash guard carefully and stick it in there. that should be good to go. thanks.
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
