MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > General Tech Questions
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 07-07-2008, 09:58 PM
Nismo G's Avatar
Bradenton, Fl
Chevron vs. Texaco w/ Techron
I know everyone is sick of looking at all of these gas threads, but i have been trying to do some research and haven't found much. There is now a Texaco station by my house and chevron has been closing down a lot of its gas stations. I noticed that on the pump (texaco) that they use techron in their fuel. Chevron also uses techron - obviously since its their product.
Anyways, to make a long story short. The amoco with techron is about .08 cents cheaper than the chevron with techron and from my knock sensors and all that it seems as though it runs just as clean as chevrons fuel...any input?
-Sean
__________________
2003 OB 5AT G35 coupe -|- Apexi S-AFC II -|-Injen CAI -|- Motordyne 5/16" Spacer -|- Stillen Dual Cat-Back -|- Stillen Engine Damper -|- Tein CS coilovers -|- Tein EDFC -|- 19" Volk TE37 -|- 1/4 mile = 13.86 at 100.4 (no damper or suspension) -|-
Old 07-07-2008, 10:01 PM
redlude97's Avatar
Post-Virgin
chevron corp owns both, I would suspect they are the same gas
__________________
06 6mt Diamond Graphite G35 Coupe
-The beauty of online forums is that you can always get the answer you want to hear regardless of their qualifications
Old 07-07-2008, 10:06 PM
Nismo G's Avatar
Bradenton, Fl
I just looked it up on chevrons website and found that they do in fact own texaco...i never knew that . I wonder if there is a difference in the fuel...how could i find out?
-Sean
__________________
Old 07-07-2008, 10:13 PM
dofu's Avatar
"Member"
There isn't a difference in any fuel from company to company... just the additives, and if they use the same additives, then everything is the same.
__________________
'05 Black Obsidian G35 6MT Sedan - slightly modded
Old 07-07-2008, 10:21 PM
Nismo G's Avatar
Bradenton, Fl
Quote:
And you know this how? That wouldn't make much sense...every company makes things differently.
-Sean
__________________
Old 07-07-2008, 10:49 PM
Quote:
-Sean
He's right, gasoline is a fungible product, companies put it into a pipeline and then pull out that amount elsewhere down the line. The fuel is the same until it gets to the fuel tanker, that's where the additives are put in. Very few ppm at that. There'd be no way for every company to separate fuel on its way cross-country.
__________________
New 2006 LS Coupe owner!
Old 07-08-2008, 06:59 PM
Nismo G's Avatar
Bradenton, Fl
Texico is owned by chevron by amaco fuels is owned by Bp...why would bp put in techron a product of chevron?
-Sean
__________________
Old 07-09-2008, 10:07 AM
^^this is 100% correct. people get so wrapped up in what gas they use.. it boggles my mind sometimes.
__________________
bye bye '05 G35 coupe -> 2008 - BMW E93 335i - White/Red -6MT - Fully Loaded - 35% - M-Technik
Old 07-09-2008, 01:11 PM
redlude97's Avatar
Post-Virgin
Quote:
The base gasoline may be the same, but the additives are what differentiate between gas companies, and those DO make significant difference, and those SHOULD be used to choose a gasoline company to use.
__________________
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
