MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > General Tech Questions
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 08-12-2008, 12:05 AM
Unhappy My G turns off on tha road !! need advice
picture this, getting off the freeway and onto a onramp. slowy engaging brake as i approach. properly shift into lower gear and turning... all of a sudden engine light appears, no accelleration, and no powersteering?!?! have to manual control car and when its save turn key and start it.
-this happend on 4 occasions within the last year.
ok so like it says. my 2003 coupe turns off and i have to restart the engine while in movement. i lose powersteering and accelleration and the brake feeels wiery for the time until i restart the motor and all power comes back. i have one of the first models out so is this the problem? other factors may be tire pressure?? aftermarket mods?? stumped. i bought the car used with a stillin intake and exhaust system already installed. and this happened like once before i did anything else to the car. ??? help and advice from anyone with knowledge of this?
another small thing that is the last of my worries is i get alot of rattling? but i hear alot of other people to aswell. and moreso after i installed jwt clutch and flywheel but still. what is this noise coming from? my tranny or engine?
*please help i do not want to give up my baby over this. im seriously considering buying a 06 and swapping my parts over
__________________
.scotte
Old 08-12-2008, 12:48 PM
bythabay's Avatar
wow, that really sucks... maybe scan your G for hidden codes?
__________________
Maintenance, modification, and repair services. Email me for info. info@infiniticare.com DIY Video Series: http://g35driver.com/forums/g35-seda...eo-series.html
Old 08-12-2008, 01:48 PM
How far are your RPM's dropping when you depress the clutch? Might need to bring the RPM's up a notch.
Old 08-12-2008, 02:02 PM
i would take the car into the dealer... I hope you're still under warranty and i remember hearing rumors about the 1st batches of g35 with electronic issues. hope you're under warranty still
with a lighter clutch and flywheel you will definitely hear more chattering from those parts.
__________________
i smile every time i look at and get behind the wheel of my car
Old 08-12-2008, 02:06 PM
Sinister350GT's Avatar
Twin Turbo Member
Check you cam and crank sensors sounds like you are breaking a electricial signal for the drive by wire.
I would spend an afternoon tracing your wiring harness under the hood and ensuring all elec plugs are tight and conntected. then take it to the dealer.
Do you know what engine code its throwing?
LOL this happened to me but much more serious.
I broke my timing ring off the fly wheel during a down shift. I broke my crank pos sensor.
If you timing ring is loose or the sensor is loose this could happen just as you described.
TIMING RING on your flywheel
__________________
03 DG G35 6mt coupe w/ Built Motor & Greddy TT kit with FMIC 544Wrhp 535 Ftlbs tq. UPREV, S2 JWT cams, Ported heads, Greddy Boost & Turbo Timer, 750CC RC Injectors CJ Motorsports Full Fuel return kit, Big Pump Upgrade. On-Board Computer with UpRev Cipher Software
Old 08-19-2008, 01:09 PM
Twin Turbo Member
any update?
__________________
Old 08-19-2008, 01:41 PM
Wannabe6MT's Avatar
Booo. Snow is comin
I doubt a first model year G is still under warranty, but its worth a shot
__________________
-Janik
08 G35xS Sedan BO/Stone - Prem, Sport, Nav, Tech - Temporary Winter Ride..
Quote:
Originally Posted by G35 Mass
Who's the heroin junkie on the left?
05 G35 Sedan RWD LS/Stone - Enough Mods. Stored Under a Car Cover in my Garage for winter....
Old 08-30-2008, 10:05 PM
hey bro i had the same problem and i thought that it was the cam position sensor bank 1 cuz thats what the diagnosis pulled up P0011 but it actually might be your timing you might have to much advance timing.
Old 08-31-2008, 12:21 AM
BlueDevilBAMF's Avatar
Wat?
The way you describe it you're not in neutral for long, but if the RPMs drop below ~1000 at highway speeds while in neutral with a stillen intake, you'll stall.
__________________
<<<<<'04 DG 6MT Coupe>>>>>
| Stillen CAI | Z-Tube | AAM Angled Spacer | Fast Intentions Intimidator Exhaust | Fast Intentions HFCs | Ruff Racing R278 in Hyperblack |
| 350Z H-techs | 35% Tint | Clear Corners | High Power LEDs | LED Turn Signal Mirrors | '06 Coupe Projectors |
NGC
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
