Fuel Shutter Valve replacement
Old 09-02-2008, 07:07 AM
CreativeDesignZ's Avatar
Ok well last night i went to the gas station to get some gas and bam, seems as if the fuel shutter valve has gone bad. the guage reads normal, but filling up is a bi*ch. Is there any DIY on replacing the fuel shutter valve? Thanks!
Old 09-02-2008, 08:36 AM
jasoncham2003's Avatar
have you tried other gas stations or pumps? I have gone to only 1 gas station since i have owned my car for the past 2 years and every once in a while i get a pump that just has too high of a flow valve. and will click off every second. if i go to another pump it works fine.
Old 09-02-2008, 05:01 PM
tried a different pump this morning and i still had the same problem, actually it was even worse than it was last night, its was barely letting 15 cents worth go in at a time...
Old 09-03-2008, 09:57 AM
well brought my car into infiniti this morning, having them fix my drivers side seat that moves forward when i hit the brakes, my driver side axle click, and the shutter valve. I was pleasantly surprised as i thought my warantee had run out, i still have 2 months left =]
jsimonk
12-22-2023 03:49 PM
Muski_G
12-01-2023 11:11 AM
Herbbie Hablib
Forced Induction
08-11-2015 06:22 PM
yassy
08-09-2015 07:31 PM
Quick Reply: Fuel Shutter Valve replacement
