Sign in using an external account
Thread Tools | Search this Thread | Rate Thread | Display Modes |
Tire pressure light on...but pressure ok
__________________
2006 G35x Sedan // 2012 Mercedes C300 4matic // 1988 Mustang 5.0L 5-spd |
as soon as I swapped my rims about 20-30 mins into every drive going above 60 mine comes on... first time it came on I freaked out pulled the car over checked each tire. and as soon as I turn the car off and turn it back on it's off... if yours is staying on you may have a faulty sensor
__________________
Too many mods |
Guess i'll have to take it in then if it doesn't go away shortly
__________________
Ok, did a little more poking around.
My car has a full size spare. Basically it's a 5th OEM wheel in the trunk. I guess when the previous owner got new tires, he put one wheel in the trunk, used the spare and bought 3 new tires. I bet when i check the date codes in the AM, i'll find 3 are newer. Anyway, does the full size spare carry a TPMS? I found the spare had a nail in it and was completely flat with 0psi in it. I plugged the spare and will fill it in the AM. Does the car read the pressure in the spare if it's the full size??
__________________
usually cold weather will set it off, should go off when the tire warms back up
sometimes it takes a while to turn off though
Well it still hasn't gone off.
Does the full size spare have a sensor? I'm convinced one of my wheels is the spare tire and now the priginal is in my spare tire well. I just have no idea how to tell which one was the spare wheel though
__________________
its the cold weather messing with your tire pressure light, had the same problem but it went away.
__________________
05 G35x- DG, + mods http://www.cardomain.com/ride/3103506 |
TPS issue....?
You need to keep the recommended pressure in your tires (35 to 37 PSI) cold.
Only then will you know if one of your sensors is defective. You should be able to look at the stem on the spare to tell if it contains a TPS....or not Gary
__________________
G35C "Twilight Blue" Volk SF Winnings/MichelinSS/DBA/Hawk/StillenSways/PowerGrid/UpperStrut Bar/Tein/TokicoDs/Nismo/Fjuita/MD1/2"SpacerISO/HKS Exhaust+XPipe/FastIntentions/SXEXCX/Gordee/NRG/Gialla/KurumaZ/Impul/Projectors/JDM Tails & Clears/Debadged/KJ Knob/Autometer/SAMCO/AMSOIL/WIX/Osiris |
Quote:
Tire pressures drop about 1psi for each 10 degrees F in ambient temperature, so if your weather has gone from 80F to 40F, your tires are probably low by 4psi not just before you drive, but all the time. That's not the temperature messing with the sensors, the tires are actually low, and driving alone won't bring them up. Your tires will increase about 3-4psi as they heat up after you drive on them regardless of the temperature or pressure that they start at. If they start at 35psi cold, they'll increase to maybe 39psi when hot. If they're at 31psi because it's 40 degrees colder, they'll only get up to 35psi from driving, which means you're still 4psi low even when they're hot. To the OP: If you measure your pressures cold and they're up to spec and you still get warnings, you might have a bad sensor. If you dropped them to 32psi warm as you said, they're probably well under 30psi cold.
__________________
It was something different.
It was because i was driving on the spare. I was right, the original owner took the full size spare out of the trunk, put it on the car and then bought 3 new tires. The original is in the trunk with a worn tire. I took it out, swapped it withthe spare tire (the cleanest wheel withough a nick on it) and the light went away after some driving. The spare also has a TPMS sensor on it. My options: 1 swap tires between the spare and the one with the registered TPMS. My "spare" tire is worn, so i'd like to replace it anyway. 2 have the TPMS reset to the 4 wheels on the car....replace tire on new spare at my whim.
__________________
Mine went off when i just accelerated onto a freeway in the rain. Got a little slippage and it turned on.
I thought somthing broke at first haha
__________________
"A Line Has Been Drawn."
'13 G37xS Sedan Moonlight White/Graphite-Premium/Sport/Nav ![]() --OEM Midnight Grill, Deck Lid Spoiler, Illuminated Kick Plates-- |
do all g's come with the TPM? because i had a flat and had to drive it about 1 or 2 miles and my light never came on. i got a 03 coupe m/t
__________________
HellaDopeIndustries.Com
Quote:
Wannabe6MT, what probably happened to you is the tires were reading the rear and not the fronts since you were spinning and tripped the code because the other two in the front wern't going fast enough. As for the trunk full size spare yes it is has a monitor in it, but it does need to be reinitialized to work, if you move your wheels and tires around you should always have them reinitialized. I do every car i work on, some are more sensitive than others to that (read: m's and 09+fx's) The G's will be fine but if you do have your spare wheel on there, and the original wheel in the trunk the tpms light will be illuminated since you have 1 tire on there that isn't registered to the bcm, the one that is registered isn't sending off a signal that the bcm recoginizes, becasue its not moving so its not giving off a reading. wow that was long winded. |
Quote:
Yup, now i have to decide. Pay to have them reinitialized, or pay to have the two tires swapped because i want to put the nice brand new "spare" wheel back in the trunk in case i ever damage a wheel.
__________________
| Tags |
| 2005, 650, cold, does, extreme, g35x, infiniti, light, pressure, recommended, temperature, tire, tires, tpms, weather, yk, yokohama |
| Display Modes | Rate This Thread |
