| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
shaky steering wheel
Hey everyone....did a search for the entitled thread I just posted, but didn't get the answer I'm looking for
I've recently put 20's on my 06 g35 sedan...new rims/tires, mounting, balancing, the whole 9 yards... my problem is not consistent, more of a problem that occurs only a few times when driving each day the steering wheel gets very shaky, usually at the cruising speed of 50-60 mph, if I slow up it will sometimes keep shaking...could this just be the issue with rolling 20's? similar problem/solutions? |
More than likely one or both of your front tires are not balanced correctly. I had the same thing happen when I got my 20" rims and tires mounted and (supposedly) balanced by NTB. They didnt' balance them properly, I had to take them to Discount Tire, they recommended a 'dynamic balance' as opposed to a standard 'static balance' (meaning instead of one row of sticky weights, they put 2 rows of sticky weights since the rims are wider than OEM.)
I would have them double checked for incorrect balance again. If this is not the case, did you purchase hub centric rings? My rims were very hard to put on the first time after I installed hub centric rings, it took a couple of times tightening down everything. Make sure your rims are tightened down evenly and flush to your rotor.
__________________
'04 G35 Coupe | Obsidian | Graphite | 6MT |Premium package | DVD-Navigation | 4-piece Aero kit | tint | Clear Bra | brushed-aluminum pedals | clear corners | door escutcheon mod | K&N drop-in filter |
| Tags |
| balancing, fast, g35, g35driver, shaking, shaky, steering, tighten, wheel, wheels |
| Thread Tools | |
| Display Modes | Rate This Thread |
