Blower fan for climate ctrl not spinning - intermittent
#46
Bumping since it's cold season and I'm seeing other threads with people experiencing this issue. On the comment above about your 2007 sedan fuse panel looking different from my pictures - it should look different. 2003-2007 coupe is 1st gen whereas 2007+ sedan is 2nd gen. PN for the relay is the same and it seems to be a a common failure point for both generations.
#47
#48
Your sedan fuse box is almost identical to the coupe. The biggest difference is the sedan has 4 relays on the backside of the fusebox instead of the 2 relays that the coupe has. According to the sedan FSM, the blower relay is in the same far right location that I noted in the DIY for coupes. Tinypic stopped hosting my 3rd picture that shows the backside of the fusebox but you should get the general idea if you read through my steps above.
#52
Thank you all for this thread.
I have a 2007 G35 sedan and the relay was the problem with the fan not working. I think the relay contacts get stuck and it takes a bump on the road or to heat it up to operate; so after 10 minutes the fan comes on.
I bought the replacement relay at Autozone and it was a Nissan part manufactured in Japan. I agve them part number 25230-79942 and they ordered it for me. It was not in stock.
In the 2007 sedan the fuse box is vertical and the relay is located at the bottom of the fuse box, behind the fuse for the "Fan".
nineiron (10-11-2014)
#54
#55
Issues started to happen for me when the winter cold started coming in. Luckily, or not, this seems to be a common issue with our cars that seems pretty well covered in terms of the fix.
Anyway, got an $8 relay from Amazon which did the trick. Changing the relay in the cold wasn't fun though. Good thing it is simple.
Thanks guys.
Thanks guys.
#56
#57
Works like a charm!
I recently reviewed this thread for my 2006 G35 and followed the steps exactly and bam, the fan blower now works like a charm! The Blower Motor Relay cost me $27.24 from RockAuto. Without this thread, I'm sure I would have paid a fortune for a mechanic to fix. The key was finding the relay behind the fuse panel which this thread shows. Nothing that I owned or could find in the manual showed me where was this was. Much appreciated and hope this helps others with the same problem.
#58
Life saver
I went a full year without my blower motor working. I bought a new one when i was misadvised that my old one malfunctioned. Next, they said I needed a new resistor which happened to be installed in the blower motor. So when i bought the new blower motor i bought a new resistor. Took it to the Infiniti Dealership, they told me i needed a new blower motor once again. I told them i just replaced it. Came across this forum and followed the instructions. Replaced the well hidden relay. Blower works!!!! Thank you!!!!
#59
