Help,,car wont start! :/ 2005 G35 coupe
Old 10-24-2011, 02:31 AM
nelbarr's Avatar
Exclamation Help,,car wont start! :/ 2005 G35 coupe
Hi everyone, I am new to this forum and just encountered a problem with my 05 g35 coupe, manual transmission. I decided to change the spark plugs and before i started I followed a DIY spark plug threads and I went ahead and removed the battery cables negative and positive first then went ahead and removed the bolts to get to the spark plugs. I finished putting in the spark plugs and all bolts and went ahead and plugged the battery terminals but my car wont start now! :/ my battery is good because the radio, interior lights work fine, can anyone please help me out? I would really appreciate this so much, thanks.
Old 10-26-2012, 04:05 AM
bythabay's Avatar
Could you provide a better description of the car not starting? Does it crank at all?
Old 11-04-2012, 12:48 AM
tle.88's Avatar
Make sure all the spark plugs are gap right. You could have mix the coil packs with the wrong wire.
Blakelyg35
08-15-2015 12:12 PM
kenthung
07-21-2015 05:56 AM
AustinErkl
Drivetrain
07-18-2015 05:44 PM
Scredeur4
Steering & Suspension
07-17-2015 06:30 AM
quickspeed6
24
07-15-2015 11:06 AM
Quick Reply: Help,,car wont start! :/ 2005 G35 coupe
