Replacement Air Relief Valve (Coolant System)
Old 08-12-2015, 08:37 PM
Greg Huston's Avatar
Hi,
My coolant "air relief" valve broke, I tried removing the bleeder screw and the brittle plastic cracked and my car puked coolant everywhere.
Now I need to find a replacement. The parts diagrams I've seen don't show the part or part number for what I need. I searched like a **** and couldn't find anything! Does anyone have a part number or a website where I can buy the part? Any help is greatly appreciated.
You can see the valve in the middle of the heater hose below.
Old 08-12-2015, 09:50 PM
coffeysm's Avatar
Originally Posted by Greg Huston
Hi,
"92500U-Connector Heater Hose"
I had the same thing happen and it shot all over my face, eyes, and mouth. Luckily, it was only warm, so I didn't get injured. I don't even use that valve anymore when I mess with the coolant.
Old 09-14-2016, 10:36 PM
arianeb24's Avatar
So i didn't see an answer i have the same problem and cant find a valve anywhere..help
Old 09-15-2016, 11:50 AM
coffeysm's Avatar
I gave the generic part number in my response. I think it's 92500-AR000, but I'd just get a new section of hose that valve is dangerous in my opinion. It gets brittle over time and I'm not the only person to have it crack. You can get air out without even using that and I don't even touch it anymore.
Old 09-15-2016, 01:01 PM
telcoman's Avatar
Have you tried the Infiniti dealer parts department?
If it broke during a dealer repair how would they fix it?
Telcoman
Old 09-15-2016, 06:58 PM
arianeb24's Avatar
Is it ok not to have it? It doesn't cause the car to overheat if i just run a straight hose? I finally found one today at the dealership for $18 but i haven't went to get it yet.
Old 09-25-2016, 11:36 PM
Swaglife81's Avatar
Z1 has a replacement relief valve with a t tap built in for a threaded sensor like to run a water temp guage. Price was $20 or so from what I remember
Muski_G
12-01-2023 11:11 AM
Blakearold
08-27-2015 12:37 PM
Frostbite91
08-02-2015 04:59 PM
joedaddy1
07-28-2015 02:58 PM
lemmy999
07-25-2015 12:13 PM
Quick Reply: Replacement Air Relief Valve (Coolant System)
