MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > The Lounge OT > The Lounge (Off Topic) > HEALTH and FITNESS
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 07-22-2008, 01:46 PM
Any cons when doing cardio and weight lifting on the same day
I've been weight lifting and then I do cardio for about 20 minutes. This is what my schedule looks like.
Mon - Back and Triceps/30 minutes on the treadmill
Tue - 1 hour on the treadmill
Wed - Legs and abs.
Thursday Chest and biceps/30 minutes on the treadmill
Fri - 1 hour on the treadmill.
I plan on doing this for the next four months. Depending on the results I see then will determine how I change the diet and the work out. Basically trying to cut and I'm doing high reps.
Old 07-22-2008, 01:47 PM
Just don't burn yourself out.
__________________
Ginger ;-) 2006 G35 Sedan 6MT | DG / G Premium | Aero | Nav | Sirius Modded.
Old 07-22-2008, 01:48 PM
03dgcoupe's Avatar
~matt~
depending on your workout running is bad after power lifting if your trying to bulk up per say...it usually will tone or eat muscle up if you run more the a mile and a half to two....everyone has a different body makeup tho
__________________
03' 6MT coupe...in need of some "GO"
Old 07-22-2008, 02:20 PM
Yeah I'm not bulking up. I'm not even doing close to my max in any of the lifting sets. Just high rep stuff.
Old 07-22-2008, 04:12 PM
1 hour of cardio is a bit much i think. 30 minutes or so is usually good enough. do too much cardio and you will start to burn off muscle. from experience and other gym rats, they agree that 1 hour is a bit much unless your training for endurance runs. if cuts is your big concern, if you had your eating down to a T, you can get cut from that depending on your body type/build. A few of my boys that do competitions don't even hit cardio that often and are cut up. genetics plays a big part as well tho
__________________
2004 6MT G Coupe\Laser Red\Aero Pkg\Brembos\Navi\stock for now
Old 07-22-2008, 05:22 PM
RBull's Avatar
Runners FTW
I suggest you change your program to lift at least 2x per week on all body parts. Cardio on the 4 days is good but the intensity and mixing it up is important. On one of the 4 days I recommend you add 5 minutes each week to the duration of the Friday run cutting back 30% or so every 4th week, going up to 2 hours or so. I also suggest on one of the other cardio days you add intensity -either intervals or lactate threshold runs. Consider biking on a couple of those days for 30 minutes or so of the program to mix it up and balance your leg muscles and minimize injury.
Old 07-22-2008, 06:07 PM
ABQ_G35's Avatar
Disabled Veteran
Quote:
Best advice here!
__________________
Today: '07 G35S, Black Obsidian/Graphite/5AT/Nav/Premium/Spoiler/3M 35% ColorStable Tint/3M Scotchgard™ Paint Protection.
Yesterday: '05 Sedan Lakeshore Slate/Stone Day Before: '04 Sedan Brilliant Silver/Graphite
Old 07-22-2008, 08:21 PM
Goonar's Avatar
Geee Man
what happened to your shoulders?
__________________
06 DG Coupe 6MT | Fully Loaded | 18% Tint | Volks | JDM | Fast Intentions | H-Techs | V1 Hardwired | Stillen | Falken 452 | BlueBat
redlude97's Avatar
Post-Virgin
don't lift and do cardio on the same day, they are counterproductive
__________________
06 6mt Diamond Graphite G35 Coupe
-The beauty of online forums is that you can always get the answer you want to hear regardless of their qualifications
Old 07-22-2008, 08:37 PM
jjyellow's Avatar
I run for 30min before I lift weights each time I go to the gym.
__________________
VTEC g35
Old 07-22-2008, 08:38 PM
redlude97's Avatar
Post-Virgin
Quote:
You are going to burn up glycogen stores by doing so and will not get your optimal workout in.
__________________
Old 07-22-2008, 10:07 PM
RBull's Avatar
Runners FTW
wives' tale.
In what way are they counterproductive?
You won't be burning any significant glycogen stores from a short 30 minute run or from lifting in a typical session he described. Even if you did, what is not going to be optimal?
Old 07-22-2008, 10:13 PM
jjyellow's Avatar
I kinda wanna do that right now, b/c trying to lose a lil bit of weight(3 years of not working out can put on the pounds)
__________________
VTEC g35
Old 07-22-2008, 11:08 PM
MIA BlazinVQ's Avatar
brb getting cut
Quote:
Originally Posted by RBull
wives' tale.
+1. I usually lift for about two hours and then do a 15 min session of HIIT. I'm currently cutting though (no emo), so I'm not seeing any muscle gains.
However, my strength is increasing and I'm burning fat at a rate I'm happy with... so I see no problem with doing cardio and lifting on the same day.
Disclaimer: Opinions are like a$$holes... well you know the rest.
Until I see conclusive facts that cardio and lifting will ultimately be bad for you, then I'll stop.
__________________
SFLG35
07 OB 6MT Coupe.... Work VS-XX's and 350Z S-Techs.
Old 07-23-2008, 03:26 AM
redlude97's Avatar
Post-Virgin
wives' tale.
If you do cardio beforehand, you will tap into your glycogen stores, which are used alot during anaerobic exercises(lifting weights) which will limit the maximal amount of work you can do and thus limit muscle growth. Glycogen is not replenished fast enough. Even when doing high reps, you still need to go to failure for optimal results, by limiting your energy stores, you are not getting an optimal workout.
The reason to not do cardio after a workout is that you are depriving your muscle cells of their much needed protein etc and rest at a key point in time, right after the workout. You should get food into your body as soon as you can after your workout, and cardio prolongs this so you don't build muscle as fast.
I guarantee that you will gain more muscle by alternating cardio and workouts on opposite days, rather than doing them on the same day.
__________________
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
