MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > The Lounge OT > The Lounge (Off Topic) > HEALTH and FITNESS
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 08-11-2008, 04:00 PM
Question about cardio!
I need some input.
Should I do the treadmill for about 30-40 minutes at so so speed, or run the mile at a high intensity(should only be between 8-9 mins according to the treadmill). What's the best route to take? Trying to lose some fat.
Old 08-11-2008, 04:53 PM
redlude97's Avatar
Post-Virgin
to lose fat, you are better off with the lower intensity longer duration cardio
__________________
06 6mt Diamond Graphite G35 Coupe
-The beauty of online forums is that you can always get the answer you want to hear regardless of their qualifications
Old 08-11-2008, 07:39 PM
RBull's Avatar
Runners FTW
You will burn a lot more calories running easily for 40 minutes than fast for 8-9 minutes. Somewhere around 400-600 versus 100-125 or so depending on your pace and your size.
Old 08-11-2008, 07:41 PM
Agreed....
__________________
Team Nextstage Sponsored by Meguiar's
Old 08-11-2008, 08:26 PM
what they said, and if you lift weights do cardio after not before.
Old 08-11-2008, 09:12 PM
dude its the best to do some own research cause theres seems to be alot of myths out there vs the facts
__________________
4doors can play to..just a little faster so keep up with the set pace haha ----Im a believer....anit-obama-ism
Old 08-11-2008, 09:17 PM
Corvettekid's Avatar
My name is bold!
One of the easiest ways to burn off fat, or calories, is to change speeds throughout your workout. If you can, or plan on, running for 45 minutes, warmup for 10 minutes, then go 3/4 speed for 5, then go normal for 10, then go hard for 10, then go normal for 5, then go hard for 5, etc, etc. That is one of the easiest ways to burn off fat, and raise your heartrate. People who run at the same speed for a long time, dont do anything after about 15-20 minutes. Yes, you burn, but you significantly drop after 15 minutes, the amount you burn off.
__________________
03 DG Coupe/06 Blacked out projectors with LED's/LED Clear Corners/LED interior/4080 with W6
Old 08-11-2008, 09:37 PM
absolutg's Avatar
workin...
yeah interval training is way more efficient
__________________
a simple black sedan
Old 08-11-2008, 10:08 PM
Quote:
yp 20 min at most also do it in the morning when you wake up lol.
__________________
Old 08-11-2008, 10:41 PM
Damn, it gets so boring when I'm on the treadmill. Oh well, I'll just try doing longer periods.
Old 08-11-2008, 11:10 PM
emtguy05's Avatar
so 20 min at various speed is better than 30-45 mins at a constant normal pace? I much rather do 20 than 45. Treadmills are boring unless there's a hottie nearby to check out while you run.
__________________
03 Laser Red coupe 6mt|Brembos|Navi|Premium Sound|Spoiler|10% tint all around|USA SPEC Pa11-NIS
Quote:
Go ahead. Skin it. Skin that smoke wagon and see what happens
Old 08-11-2008, 11:11 PM
absolutg's Avatar
workin...
yeah there was a study that showed like 25 mins of interval was more effective than 60 mins of steady cardio
__________________
Old 08-12-2008, 01:07 AM
MIA BlazinVQ's Avatar
brb getting cut
Quote:
you won't be bored with HIIT, trust me.
here's a basic outline of how you can do it (you can change it up however you want): 2 minutes of warm-up at moderate intensity >> 20 seconds of balls to the wall (all you fvcking got!) >> 1 minute cool down at low intensity >> repeat 20 seconds of insanity >> 1 minute cool down >> after you've reached 15 minutes of doing the cycle, cool down for about 3-5 minutes and you're done.
__________________
SFLG35
07 OB 6MT Coupe.... Work VS-XX's and 350Z S-Techs.
Old 08-12-2008, 01:15 AM
lekker_droom's Avatar
fvck you
Nailed it! I lost 30 pounds in 2.5 months doing 30-45 minutes of treadmill 3 times a day. I had the incline at 8 and speed at 3-4 miles an hour.
__________________
2006 IP Coupe 6MT
Stillen || 350Evo || KW || Motordyne || Fast Intentions || ARC || Toyo || OSIRIS || Rogue Engineering || SPC || Grounding Gear || Powergrid
Old 08-12-2008, 09:24 AM
RBull's Avatar
Runners FTW
Quote:
This information isn't factually correct.
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
