View Full Version : G35 Coupe V35 2003 - 07
- Are these coilovers the same as MDU?
- 4080 subwoofer question
- Will this fit 06 sports bumper?
- Engine Temperature Seems High
- Question about ViS diffuser from new owner
- JWT pop charger question
- 04 to 05 wheel swap
- suspension setup question..
- Agency Power pulley set - need info
- Got Bitten - Mods Ordered
- 18x8 40et and 245s anyone running this on a coupe
- To KurumaZ owners...
- Rear window trim necessary?
- Finally Got My G!!!! YES
- Painting my stock Calipers Black (pics inside)
- really annoying sound, any help!!
- Front bumper protector
- G35 Hid pics
- price for my car?
- A few new mods
- Easiest cheapest "mod" to the interior ever!
- Coolant Control Valve
- escutcheon cover on driver side install
- Front lip?
- UTEC parts needed... Molex connector/mounting ecu standoffs.. any advice?
- Worst Day Ever
- $$ offered for help.. Weird noise from drivers side wheel area.
- Thinking of installing a deck
- need brake direction
- 2004 coupe 105,000 miles...What needs to be done?
- NEED HELP - thinking about going Lexus IS -> Infiniti G35, pics and Questions please!
- daily driver, Buddy Club Racing Spec ?
- What brake pads should I get??? Suggestions/Help please...
- Alignment off- DO I need Caster, camber, toe kit?
- Picking up my 03 G35 Tomorrow!
- Got my G!!
- What you think of this OB Coupe?
- what do you of these wheels?
- Front, rear or both splash guard?
- What do you guys think about my headlight mod.
- Need Suggestions (Arch vs Strafe parts) and Lowering Springs?
- Whats a good price?
- any such thing as a g35 skyline package?
- Missing intake parts
- have you ever seen these rims?
- Not meant to be?
- (Oil Filter) Question.....
- ArmorAll Stickies? ew.
- Question about a fishy 06 g35
- Rear Rattle Problem (interior)
- step light fitment?
- Could this be real??? An Accord???
- Hold throttle 30 seconds, more performance?
- Been here for awhile and 1st pic of my 03 G
- To be continue..... with pics :)
- Touch up paint/scratch remover products
- roof overlay...xm radio
- wheels question
- Is my 06 base model pre-wired for an amp in the trunk?
- Slip, engine soon, VDC light ON
- Stock Y Pipe replacement
- Clutch with stock flywheel
- o2 sensor problems.....help
- Driver Side High Pressure A/C Line Repair in Miami
- Where can I buy this?
- Electronics are acting up
- My Jersey People!!!!!!
- Transgo valve body install problem!
- Messed up, taking out starter - Car on jack stands need help!
- Help! Is my G consuming too much oil?
- What you think? Blue or red
- PLEASE help, g35 with g37s rims-tires
- Just moved back to Miami...
- Problem with Metra Kit
- Stock G drives like a boat!
- Does this G look fishy to you?
- New to the forums. LOTS of Questions XD
- Front wheel hub replacement, I have 2 options?
- what should i do to fix my cracked leather seats? (pic)
- tires
- What's the difference...
- Engine swaps for g35
- Formula One
- Whats it worth?
- SunVisor G35 2006
- Rim Choice newbee
- 2004 G35 Coupe Smokes after replacing tube seals. WTF?!
- Interest for Bolt-In Harness Bar
- Smog Test for Modded G35
- How much would my car be worth?
- Exhaust problems. Please share some insight.
- Free 06 6MT Coupe gauge your 03-04 6MT guage - LOCAL ONLY
- Front Bumper?
- noob question: spacers on winter rims?
- Some wishful thinking
- Help..I lost my side marker and full harness only wires exposed
- New G!
- Rear deck / parcel shelf removal assistance
- Check out the New Whippp
- What mods does he have?
