- help...car "jerks" when accelerating
- HELP...Dead battery when leaving car in ACC for 5min
- Switching from synthetic "blend" to full synthetic
- City light replacement help?
- Do reverse lenses fit headlights?
- Castrol Gear Oil
- Sevas s7 or s22's
- Romoval of Maplight trim
- best oil for our cars?
- headlight and tail light restoration
- oemclutch chattery or is it my tob?
- Engine Question
- Pillar Replacement
- Intake Question...
- Oil change - time duration or miles driven more important?
- Wanting to get a DROP on my 06 OB coupe
- Tips on where to get key cut/progammed
- Fog Light fuse
- Spring Mod Bugs rampant!
- Deciding between Flowmaster and Magnaflow muffler swap Any suggestions
- What is F**ked? Please help.
- someone please explain clutch chatter
- braking light", "slip" and the "traction control" light are on
- Real carbon fiber roof cap?
- Post your G35 wallpapers
- Does anyone know?
- motordyne vs hks exhaust
- something im see'n alot of lately
- 06 to 05 wing conversion
- 07 Coupe with 22s
- Anyone elses fender feel WARM after a few minutes of driving?
- Quick Question
- Lower Bumper Grille 04 G35 coupe
- Would the 2005-2006 floor mats fit in my 2003 G35 Coupe MT?
- Post the worst things that have ever happened to your G
- DIY aluminum footpedal install
- Has anybody manually installed these before?
- need Tire Size advice please
- Stock Suspension
- Axle question
- Front Compression Rod
- 60K-mile service for my 04 G35
- loud pop from clutch assembly (different from other threads)
- 2005 G35 Coupe, Eibach Pro Kit 20s
- VDC supposed to scare the ***t out of you?
- The bottom of my G scrapes! :(
- i need to change oil
- Finally Got My Custom Painted Rims
- Amsoil Severe Gear 75w90 in 6MT
- Rear Diffuser for G35 coupe
- Wanted 05-06 gps antenna
- How do you fit the G
- How good are these tires?
- New to the G35 community
- That time of year again!
- defogger timer - 04 model
- Buying Tires
- My Horrible Experience
- thoughts / hows your fiber glass bumper holding up
- quick question, help appriciated asap..
- My new shoes...19" 5 Axis s5:f's
- Does anyone know about INJEN???
- Ignition Sounds Labored
- g35 Coupe Engines????and350z?
- New Mods :) Thoughts? Comments?
- Window smashed pics!!
- V35 Projector size
- gialla grill fake or not?
- Need your thoughts on mods!!!
- Center console not working? mind of its own - please help - thanks
- IMPORTANT READ: How to make 40mm offset rims look good!
- Who sells painted 06 headlights????
- wierd noise when driving??? please help
- Airbag/Rocking Seat
- Jay- wants to know when racing is it better to turn off VDC
- Headlight strip light
- 2006 G35 Coupe Semi Automatic Transmission
- Rims
- Tune up
- Dream Car at 22
- little help with my stock burned out sound system
- Elite Extended Protection Plan
- Painted OEM sides?
- Best plenum spacer??
- Xxr 552 gold
- Jay- wants to know what should mods should i get
- MREV2 or SPACER???
- What color to paint brembo on OB coupe
- anyone not running staggered wheels?
- Door lock delete?
- breambo color choice need help
- Vin locations and common defects on these cars??
- New to forum
- Bully Dog Gas GT first Impressions
- New G coupe owner OMFG!
- LED corner markers
- Fog light bulbs?
- Weird "banging" noise coming from rear passenger side when going over bumps
- Radio mutes
- Clear Corners
