- Replaced Engine, Low Idle Then Dies, No Codes
- B&M short throw shifter install
- No tachometer No Codes No start, and not a clue
- G35 shockwave exhaust tips
- Coupe Wheel Dimensions
- Car lurching...studder while driving
- Floor Mats
- First of many questions
- Hard Steering in Reverse
- Hissing from PCV valve -
- Screw Part Number
- rear plate light bracket
- G35 Coupe - Exhaust Help
- What is this sound coming from?
- Toe out of spec
- Possible to remove all security and have no key and just a button to start?
- 05 Coupe Transmission problem, 1 gear?
- Buying my first G35 on Monday (pic)
- dome light help needed
- Door Lock Actuators
- Replacement Quarters
- Catch Can Idea
- Which fender should I buy
- New g35 owner
- sat radio woes
- Front end collision
- No heat at idle
- Same exhaust setup on different cars.
- Looking at 07 need opinions
- 2003 g35 Climate Control Pin Out from Factory to Metra Unit
- Cam & Crank sensor problem
- Help. Stutters when shifting from 1st to 2nd gear
- 245s all around on stock rays?
- O2 Wire Harness Part
- aftermarket valve cover replacement
- What condition can I expect to get for 4500?
- Trouble Code P1065
- My instrument cluster light & stereo won't go on.
- OEM length of rear lower control arm
- dented my bumper - repair or replace?
- Where's my G35 mechanics? 2004 problems
- Getting started modding
- 06 Coupe AT - what did I buy?
- R1 Slotted Rotors Zinc Coating - Gold or Black??
- Problem increasing height with coil overs
- Intake Coupler
- Reverse Engineering my G35
- P1564 Code
- Might buy 06 with exhaust and intake
- Engine sputters at high RPM
- Pros/Cons of Berk Resntd test pipe stk exhaust
- Tranny issues
- G35 Coupe Tail light relay
- Key fob works intermittently.
- car damaged at my mechanic
- FlyMotorsports Fenders for G35 Coupe
- G35 Turned off while driving
- 06 G35 having starting issues HELP!
- What Nose ?
- Weird HVAC icon? Whats it mean?
- Does this look or sound bad?
- Took off headlight and now my stereo wont turn off
- New to me G35 coupe
- 2003 Coupe sunroof opened by itself
- Starting problems
- Whistling Noise at idle (Inconsistent)
- Carbon Fiber Skinning
- 06 6spd coupe no start issue
- G35 Overheating !!! check radiator fans
- Fender Edge/Lip Rust Repair Options?
- Fender Flares to cover some rust spots on 2004 G35
- New tires. Need halppp
- Outcast garage front bumper
- Strut advice - which brands to buy / avoid
- Need Advice on Passing Emissions
- Radiator bolt sizes
- Recline on both seats doesn’t work
- Fuel Gauge doesn’t work at all
- rear lights
- Fuel Gauge
- Auto to Manual
- Navigation update DVD
- 06 automatic coupe not shifting correctly
- Urgent overheating
- General question on my newly aquired g35 coupe
- New (to me) ‘06 G35 Coupe
- Brake clicking
- P0340 fixed but there is still a problem
- Help with some info
- 12 mpg
- New G35 Coupe!
- bumper off to replace washer pump??
- Trans shifter bulb - Console
- 05 G35 - Bad ECM? I'm out of ideas - Please help.
- Auto to manual transmission swap ecu problem help?
- Jet Hot Coating? Thoughs /inputs
- Sticking rear passenger caliper... Looking for advice
- Blowing cold
- G35 acceleation issue
