- Repair ECM
- Best BBK for Aesthetics
- Stop at red light then all of a sudden check engine light P0350
- Dealership quoted me $4000.. any help??
- Rev-Up Oil pump
- Sigh... Another issue. Overheating after changing belt
- Looking for airbag parts on 06 coupe
- Tightening rear valve cover bolts?
- Stock 2JZ-GTE Twin Turbos on 03 G35 coupe
- Radiator Removal Problem (03)
- Techometer doesnt work, VDC, Slip, problems with start!
- 2004 w/194K miles and oil leak(s)
- Did I Just Buy The Wrong Brakes And Rotors??
- headlights !!!!
- Mods
- Blinking Service Engine Soon Light the. Disappeared
- Need Help! Will 06 exhaust set ups for in my 07 G35s coupe?
- 2 weird things keep happening (new 07 coupe owner)
- Is this it?
- Purrs like a kitten under 90 MPH, rattles like marbles in a tin can over 90 MPH
- Car troubles. Misfire...Hope i dont need a new engine!!!
- Fuel Sending Unit
- Car makes a loud whiny noise
- Hi, i have recently purchased a salvaged 05 6mt g35 with launch control,
- Gas tank won’t stay close
- Can overheating or overrevving cause the cruise control to stop working?
- Rattling catalytic heat shield advice
- Where to find 06-07 coupe oem SPORT front bumper
- Newcomer buying questions please help
- Need help with my 04 G35
- Toy car G35?
- Need new engine
- Bye bye G family. New ride.
- 6mt flywheel
- anyone running 18 9.5 in front with 18 10.5 in the rear with +30 offset?
- *New* Good brands ?
- Door jam seal/weathering strip replacement
- is there a settings menu in the 2004 g35 coupe
- Flushing engine coolant
- Need help taking out radio of '04 G35
- Can a muffler delete system fit in my trunk?
- Healights...
- KeyFob Modification- Flip Key
- HELP installing H1 Foglights
- Worth fixing before selling? Or forget and take what I can get?
- will a 2005 g35 coupe hood fit on 2007 coupe?
- Anoybody know what this tank is for? (is completely empty)
- How’s my suspension look?
- V35 revving uncontrollably on start up. Cannot drive it!!
- Swapping non revup to 06 revup g35
- What all can I swap frI’m a g37?
- Megan Y pipe with muffler delete and test pipes
- express aero kit
- Wheel/tire size for wheel gap(stock)
- dont like the old grille. quick spray over
- Drivetrain slack on/off throttle still!
- Can this be fixed? How hard?
- Buzzing/ Whirring sound coming from the front of the motor
- whats a better deal
- 2003 G35 coupe p0102 code
- Car over heated, can't find problem.
- VDS/Slip light
- Fuel Pump replacement
- RAYS & 25mm spacers
- Heat seat button fell through
- Question about tie rods
- What wheel offset for stock suspension?
- Service engine soon light came on help.!
- Lip for 06 G35 Sport Coupe????
- Lowered G35 Coupe Tread Wear
- To rebuild or to swap?
- My car is getting dangerous
- OEM rays/ what brand wheel spacers do you use?
- Question about Jdm g35 motors
- Help
- 05 Coupe Headlight Issue
- Is my oem pump going out?
- Windows.
- What tires should I get for 20 inch rims
- Question about 5/16 or MREV on 07 AUTO
- 07 Auto takes force to get into Park
- LED Tail Light not working
- Hard start, rough idle.. any ideas?
- Throttle position.
- New car 04
- New To The Group & Mods...06 G35 Coupe Interior Upgrade
- Broken Pipe Attached to Muffler. Ideas?
- Sudden drop in rpms after letting off gas
- G got sideways :(
- 04 coupe overheating problems
- transmission
- Starting problems
- Had to share this deal of a lifetime I just got
- Seat Gear issue?
- Gas odor in engine bay
- My g lost all power!!!!
- g35 exhaust help
- ABS activating when Turning (wheels lock up) PLEASE READ
- TS Diffuser
- My Glove Box looks like it is undoing itself. Any fixes?
