- Just had my Camshaft sensor and some exhaust leaks fixed and wow...
- What First for my G35 2004 coupe?
- Oil dipstick On L
- Not starting
- Repaint or touch up
- 05 Coupe engine knocking in park. No other symptoms or codes
- 04 coupe touch up paint
- Snap sound driver side front
- HELP!! Can anyone Confirm:
- First mods for an 05 g35 coupe?
- how to fix the VDC off & Slip lights ?
- first time DIYer
- Sensor
- 05 Front End Noise
- G35 transmission dip stick stuck?
- 2004 g35 neutral position switch?
- Intermitent ABS Sensor Cutting Out
- Rough ride on ISR coils! Help!!
- 04 g35 tire size question
- G35 Front Rear 19" Wheel Swap
- Another Coolant System Mystery
- Air intake adapter or big holed cone
- Brakes locked on and VDC, Slip, ABS lights when moving car
- Can the G35 AT 2006 be flat towed behind an RV?
- Under dash electrical, Need Help!
- Mirror Cap g35 coupe 2004
- Looking for your opinions on exhausts
- 2004 G35 coupe
- Fitment Too Aggressive for stock camber?
- Bad Wheel Bearing, Axle, or Tie Rod?
- Ebay turbo legit?
- Supercharged g35 guidance
- Sensor or The Fuel Pump??
- Roaring and screeching noise from drivers front.
- Door screw size
- Broken windows?
- Am I crazy?
- “VDC off” & “SLIP” light on!!!
- Stopper bolt
- Cam sensor
- Help planning mods.
- Changed clutch, won't start.
- I'm Looking For A Key FOB Shell Housing KBRTN001 IC:2111B-TN001 INFINITI 2007 G35
- Rear Diff Axle Seals?
- Help please vacuum leak problem?
- HELP vertini fairlady rim 20x8.5
- 2006 infiniti g35
- Difficultly starting
- G35 randomly stalls, no cel or codes
- Trying to figure out how to drive
- Terrible idle..
- I’m lost
- How do you remove the @#$%& fan relays?
- P0300 Misfire...
- P0300 Misfire Story
- My 2004 G35 coupe sounds like it has turbo whistle..but no turbo.
- high speed rad fan not working
- Does the radiator/condensor fan unit fail as an assembly or individually?
- Anyone know what color this is ?
- Valve bucket lifter and timing chain tensioner.
- Fix, Sell, or Part Out? (needs clutch)
- G35 ignition coils
- 6MT shuddering when starting in first gear
- replacing body panels... Afraid of paint matching mishaps... any experience?
- Anybody near philly running a fast intentions or exoticspeed exhaust?
- P0442 EVAP control system how to fix??
- Catch Can orientation
- Coupe or Convert?
- Cant pedal my car
- Guys input on Work/Vossen
- rear spoiler light
- 2007 G35 Roof Rack
- Grinding type noise at certain RPM's while on the throttle.
- Cooling Radiator Fan doesn't turn on! 2005 G35 Coupe
- Coul over question
- 2003 G35 engine exchange PROBLEMS!!!
- 07 G35 Coupe overheating!!
- Aftermarket backup camera on factory navi?
- Need help with my 04 G35
- Rust repair opinions....
- Prefered online vendor for sensors?
- What wire harness for pioneer single din?
- Solid SRS Light
- Do Vossen CV5s clear akebono ?
- Is around 15 mpg normal for aggressive driving style?
- 04' Coupe Radiator Fan???
- No power to aftermarket head unit
- Headlight recommendations for 03 G35 Coupe?
- Tail Lights Won't Turn Off (Not break light switch) Help!
- can anyone tell me whats happening here?
- How can I get the top clock bezel flush to the dash?
- question about muffler ticket
- Rocker Arms
- Starting Issues - 2003 g35
- Is it possible to just use oem din as a double din?
- g35 wont go over 2200 rpm please help i think its in limp
- HELP! Random unkown cable!?
- Only control to move back and fourth works on driver seat
- DIY Clear TPMS Signal
- new ley works only one time after successful programming
