View Full Version : G35 Coupe V35 2003 - 07
- Quicktrick alignment
- Reprecussions of Unplugging VDC Relay box
- 06 Coupe FSM
- Issue with passing Technical Inspection due to Xenon headlights
- g35 transmission
- Looking to clean up my G, looking for suggestions! (lots of images)
- G35 rim squek and brake smoking
- Cheap Clutch or Expensive Clutch?
- Test Pipe Sound?
- VDC off, Slip, Brake and Battery light on. Any help friends?
- Non Staggered Rims
- Swap engine m35
- 200k miles still going very strong need help.
- p1283 code wont go away
- My g35 won’t go over 4K rpm After new muffler installation, what is the issue?
- AHH! Valve cover trouble
- fishing for leads = Elct issue
- Does anything bad happen?
- What does the 5AT monitor for manual mode?
- Poor acceleration and car shakes
- 2006 couple rattle when put in reverse
- OEMish Foglights?
- new G35 owner from the UK with issues
- nissan 350z and master window switch and motor are the same as infinity 2003 g35
- What does everyone think about aftermarket parts, specifically the blower motor relay
- G35 Test Pipe Rattle
- Where is the oil leak coming from
- G35 Hesitation? Huge issue!!!!
- need a tune for test pipes
- G35 Coupe 2006
- misc wire connect- help!
- my kia rondo 2008 is making a womp womp sound from the front end, what could this be?
- Is this fixable? Engine block flange to transmission broken.
- What Causes The RPM's To Get Stuck?
- Looking for 2005 Infiniti G35 Coupe Service Manual
- 05 G35 Coupe, Sport Sus PKG, Front End Links needed.
- Dash Kit....
- I am I that Dumb....
- Widebody/Spacer help
- SRS Light Doesn't Blink On Startup
- Any Seattle member with oem exhaust laying around in garage?
- G35 Rattle
- 05 Auto manumatic mode problems
- Ipdm Harness repair
- Loud thud, car shake while driving low rpm
- Passenger Side Seat Connection
- white layer in coolant, normal?
- Manual transmission revision
- My G35 is @ the dealer...help
- Bank 1 coil packs with weak spark?
- G35 door handle
- Road feel over 90 mpg
- 2004 G35 Coupe Overheating
- Sad Update on overheating
- Still overheating. Wtf
- Buying an Oil Consumer
- Overheating. Please help
- CAI or Stock Hose Assembly..
- Alignment results, need help
- Previous Owners...
- G35 2003 unknown part
- Back Up Camera install and recommendations for 03-04?
- Screeching after a plenum install
- What’s a fair price
- Thumping sound coming from directly under under me??
- Wheel bearings
- Exhaust shops NC- Charlotte Area
- Bushing Upgrade input
- 2007 Infiniti G35 Code B2911
- Headlight description
- Timing chain tensioner
- No spark no injector pulse
- Strange Transmission Noise
- Want to buy back my G35 Coupe. Can I find the new owner of it?
- Bought a wrong transmission apparently
- Auto lights not turning off
- Any alignment experts out there?
- 03 G35 Coupe -- Seat heater lights
- MAF sensor
- Dash like a Christmas tree. ABS,SRS,SLIP,VDC off
- Are my cats bad or is this problem way worse than I think?
- JDM Double din trim?
- G35 Seat wiring Harness Pin Out ID
- Am I missing a bracket holder for the license plate lights?
- Cooling fans only work on high, not on low
- Should I buy a 2007 coup
- Should I get a tow to the alignment shop?
- Shaking vibration and all sorts of bad
- is anyone selling a nonrev engine timing cover ?
- Help please need part info g35 05 3.5l
- Low idle after installing HFC?
- g35 2006 infiniti coupe
- Sputter problem
- G35 Swap and socal emissions??
- Best exhaust for the price
- Car shutting off while accelerating:
- What do you think this squeeking is?
- 05 g35 coupe width?
- *Hazards go off randomly after failed attempt to program new remote to car
- Can't get into car
