- Clutch
- 2003 g35 coupe light hid help
- New and Considering to Buy a G35
- Can install 03/04 Brembos on my 2007 Coupe?
- Wheels spacers
- Rear Console Key? replacing 3rd light
- Need a trusted source to buy my motor
- City light flickering
- What should I do to my 03 G35 coupe?
- Front bumper choice...
- Should I fix oil leak?
- Knock/shaking happening at idle?
- Clutch acting weird
- Slightly different project for myself. Suggestions?
- 12V power after the ignition is off
- Please help - not starting
- Chirping in Passenger vent
- 03' G35 Max Tire Size (19' BBS wheels)
- HID to LED conversion?
- 2006 G35 Tire Help...
- BC coilover rear adjustments?
- Lower Control Arm Bushing Issue
- Driver side power seat fuse
- Window motor installed, have some questions.
- need suggestion
- Mods on a 2006 G35 coupe
- No power but only sometimes
- Brand New Floor Mats
- Key fob trunk release now setting off alarm
- Sway Bar Endlink boot question
- Pre-Turbo Installs
- AAM Test pipes with muffler delete
- Fuse goes out
- Engine Knocking?
- Airbag blinking light?
- Axle
- g35 Window Intermittent! AGAIN...
- Coupe side skirt question
- How universal are aftermarket parts?
- 2005 G35 Stalls out P2135 strange PCM/ECM issue
- Where could i buy a shift lock cap?
- 05 Brake pad different sizes
- Anyone know where I can see more of this g35???
- Spare parts, upgrades and mods
- New clutch making noise
- Identify these splash guards
- Sexy Key Mod
- Trying to change my radiator. What are these metal hoses connected to it?
- Another VDC Slip Issue Help Needed
- Due to hurricane flooding my driver seat wont move forward or backward
- ECU Replacement Help :dunno:
- should I keep it? or nah..
- Alternator or battery?? Ebrake light + batter light!!!
- Help Needed
- Stillen supercharger hood
- Headlight cleaning...??
- Y pipe
- Poor gas mileage in Los Angeles... or my car?
- Cooling fans won't come on
- Pad + Rotor+Caliper
- What do you think about this Z Tube?
- Rear Axle Seal
- Extending rear axles?
- Help asap !!!
- 2007 G35 Coupe
- Can I install RAS if I don't have it?
- OEM Front Bumper Lip
- 6mt doesnt stall/drive in gear, shifts without clutch engine on
- What front brakes do I have?
- These wheels?
- Lights draining my battery help
- factory air intake hose
- Rear Bumpers
- How can i know how my car was lowered?
- List the bizarre things you love about your G35 coupe!
- Repaint paint? Options
- G35 in limp mode, please help!
- 05 A/T Coupe - Engine Swap Won't Start
- What does this belong to??
- Is there a key upgrade for 04's?
- Weak Start issues
- How do I tell what options my g has?
- Catch Can Questions
- Riding rough
- Plenum Spacer washers
- Swapped dashes. Now Auto/Climate control doesn't work
- PCV Valve NPT/Thread Size?
- Halo headlight wiring
- Found and fixed the problem, but need help on what caused it
- Warm start issues & RPM's stall out around 5,000
- worried about pinging/knocking
- 2004 V35, Oil light on under braking
- Brakes
- Tricky Electrical Issue (maybe not)
- '03 6MT Coupe Random Misses ^4500RPM P0300
- Chrome ring under auto shift knob broke
- Random shut off? Need ideas on what to check.
- Help with Fat Lip offset
- Need Help With Motor Swap
- Fuel Guage is Killing me!! HELP!
