View Full Version : G35 Coupe V35 2003 - 07
- Fast Intentions "Fast Delivery?!!" LOL
- 06 headlights upgrade
- New to the G35 and the board. Let's get started making HP
- Size for rims please!!!!
- Is this normal for a rear fender repair?
- Coupe in shop for 6+ months after swap, no start!! DESPERATE!
- P0327 Pending Knock Sensor Code (no CEL)
- Fixed the ole "door locks not working" issue
- Good First Mods
- 2004 vdc and slip light on
- What would you pay for this dealer vehicle? (pics)
- G35 catback
- Help with exhaust welding
- Knock sensor and oil consumption related?
- Any pics of 7spoke chrome wheels painted???
- G35 2007 door light
- Spc 73000 control arms
- Problem with keyfob, question about gas door
- Abs, slip, vdc off help please
- G35 High Oil Pressure?
- Vdc?
- Questions about going FI
- Need advice from g owners
- Scrapping Noise When Braking
- 2004 G35 Coupe VDC and slip lights on
- 5AT Exhaust Drone
- Wow would my G be considered to be a total loss?
- Would you drive this color G35?
- how reliable is 2005 coupe Automatic, with over 100k miles on it?
- 350z suspension to be installed questions
- Stillen Return Policy ???
- P0462 Fuel Level Sensor A, Circuit Low Input
- Front License plate mounting help
- Corbeau Seat Bracket Issue
- Hang with me guys. Headlight question
- Door Hanlde Swap to GT-R [HELP]
- Could this be the source of my rattle on acceleration?
- 2004 G35 coupe headliner
- Strange overheating problem with my 2003 g
- Engine Service Light ODB II Reading, Help need!
- 2006 vs 2004
- Looking to get this G
- Can anyone run a carfax for me? (PLEEEEASE?)
- why does my car keeping going into limp mode every few days?
- 2004 AT with increasing oil consumption (115k miles)
- 2003 Coupe Limp Mode
- TINT Question in Pennsylvania
- 07 G35 Coupe Value
- Problem with passenger door
- Practical lip/side skirts in these pics?
- Seat buttons dont work? I have answer
- Major fuel leak
- 2004 retrofit headlights
- Longer lugs
- "dash pocket" 03 coupe
- Preparing For a Track Day
- Need help with AC compressor change and receiver drier
- Passenger Window Motor Won't Budge!
- Exhaust
- Rarest Color Combo
- Floor mats and Seat covers
- Lowering my g
- 2 questions about my 05 g35 coupe
- Will these HFCs be enough?
- Bad clutch or pedal?
- How can I connect the JDM taillight trunk harness?
- Need a favor
- Wheel weight - BBS LM 19s
- Finally got my G35 Tuned (04 5AT) Dyno Inlcuded
- How to adjust window? doesn't seal at 60mph and has a little rattle
- 05 G35 alignment issues - HELP
- How many gallons to fill up y'alls gas tank?
- Why does the G35 community seem so cheap?
- Good independent mechanic in Spring, Texas
- Water in trunk?
- BeeR rev limiter install?
- Spacers!!! WORK wheels HELP
- Cracked upper oil pan, JB Weld?
- Cooling fans problem HELP!!
- Who bought Urban's G? How's it holding up?
- Motor swap
- Bought a bunch of parts ... Then got into an accident >:(
- What are the wheel type on this G
- $300 dollars for a key?
- Wheel Fitment Advice Needed
- Crank No Start
- 04' G35 Coupe - 249K Miles - Engine Ticking
- Buying my pop's '03 G35- any right away mods worth doing?
- Rough clutch and tapping
- Overheat during Idle, Fans not Turning
- Is this a wideband?
- Suspension Advice
- New Key cut, only locks door???
- Wow, have our cars depreciated that much?
- Wrong section, but need help
- My differential fell
- Aluminum Drive Shaft
- hood latch broken? how can I tell
- Can anyone tell if this is compatible?
- 2004 G35 Sedan Hood Paint Chips
