- 03' g35 coupe;Engine Light just turned on, help!
- 90k service
- G35 Coupe Not Starting After Stillen Intake
- repalcing ABS
- Help Please: Car locked with battery disconected
- 235/35-19 Front Tires on Rays Forged?
- scratched door pulls.
- Reverse Camera Install Suggestion Help!!!
- BMW to G35
- Borla exhaust
- Loud pulsating noise from rear tires
- Can someone tell me if there's a way to tell if used seatbelts need to be reset
- in hopes of reviving a G35 coupe
- HKS Exhaust Installed - Really Raspy - Art Pipes
- service engine soon light came on.
- Nismo
- Need to change flex tubes/y pipe, need advice.
- Fenders Rolled...losing Paint
- Did all 05-06 6mt had oil consumptions?
- runaway idle
- Rims/Tire Offset Help!!!
- "I don't have time to change my oil" - STAHP IT.
- Alternator Problem (I believe...), need a DIY!
- Best looking aftermarket spoiler?
- 03 fuel pump
- Premature Oil Change. Should I Change the Filter?
- How many of you with lowered cars take OFF the undertray / splash shield?
- New house driveway is destroying my exhaust
- What is a Borla Exhaust Diffuser
- Another Air Bag Recall by Nissan.
- Stillen Z Tube Installed
- Front lip sports package.
- o2 issues
- best sounding exhaust
- My built motor is almost done
- top rear part of my g35 coupe window hitting outer trim
- Wheel/tire specs enabling my VDC?
- What does this tick sound like to you guy? (Video)
- G35 first car for 25yr old?
- Adjusting clutch engagement point
- Arbitrary book values on our cars
- Question about body work
- G35 Noob Here!
- 07 G35 6MT questions
- Fuel level question...
- G35 with Manzo Unresonated Test Pipes/Stock exhaust
- Car totaled?
- need help on what to get
- Rear bumper problems!!
- Anybody paint their grills anything other then black?
- Time for an upgrade?
- AC issues no cold air- blower works fine
- Going from Brembos to base brakes
- Ztube/pop charger with heat sheild?
- Volk Te37 legit check?
- So I have a Jacked Up Car
- Answer a few of my questions please ?
- Installed New Taillight...lights blink on startup
- Gialla Grill on Athens Blue Coupes
- What lip fits an 06 coupe sports bumper?
- Ebay clutch kits?
- Window Reset Procedure? 04Coupe
- Ignition
- passenger seatbelt sensor?
- Tire recommendation please!
- Lookng for some personal opinions - rear body change *pics incl**
- Transmission Issues Update(info inside)
- Wheel lock suggestions?
- Need help!! My car wont start
- Electric Work (DMV Area)
- Need help with my intake
- Sunroof motor starting to slow down, clicking sounds.
- my car Is missing something.
- Best way to remove compression rod.
- Radio draining my battery!! G35 coupe
- Speedometer not working 4 codes P0500,P1212,P0550,U1001 WHERE DO I START!!!
- oil consumption in my06 g35 coupe?
- 2004 6mt infiniti
- 2003 g35 coupe slow clutch pedal
- Another Spacer threat
- Fender Liner keeps ripping...?
- Low Compression Pistions on Naturally Asperated engine
- Lock beep sound won't turn on???
- How about the reliability of Q40(new G37)? 2015 Q40 AWD($31717) or RWD ($30256)?
- Car burning crazy amounts of oil
- Carbon Fiber questions
- Should I go to a Dealership
- Replaced the Compression Rod Bushing
- G35 2004 Acceleration loss
- Pre Turbo Installation
- G35 wont start or crank, weird beeping noise. Video.
- Upstream o2 sensor confusion!
- pop charger + stillen air box + z-tube
- Idle issues/ motor turns off
- Interior dome lights question
- Sun roof flew off!!!! how to tell if it is factory?
- Gutted only one Cat and WOW!!!
- Blue G look?
- clutch problem?
- HELP!! ABS making noises when engine is turned off
