- Trunk not opening 4 beeps 07 Coupe
- Passenger window problems
- not another alarm question
- Rims
- 03 g35 coupe
- Door Lock issues even though I replaced an actuator
- Terrible Wheel Bearings
- Please name this body kit
- Low Fuel Light Stays on
- Is my G a 2004 or 2005
- not another oil question
- 03 factory ranges and settings for camber and toe?
- Where can I get a new lug nut key?
- Starting Problems
- Rear caliper guide pin head is stripped and dead. Help??
- Window/Door Issues - 04 Coupe
- newbe
- All experienced with aftermarket steering wheels in there g's
- Shifting
- CAI Heat Shield?
- Slight rod knock
- Will these rims fit my coupe?
- cel code p0462 cleaning sending units diy or more serious problem
- Intake
- Passenger side headlight out
- 06 High Mileage MT, need opinions
- Help request - need to remove G35 5AT driveshaft
- what o2 sensor part #'s to use??
- Adams rotors and project mu pads
- g35 pathfinder cooling mod discussion
- Best Oils to Use
- help diagnose DTC's from intake spacer/ valve cover gaskets install... :/
- 1.5in or 2in lowering spring drop?
- New G35 - Feedback on a few maintenance questions welcome!
- Found a clean '03, <60K miles
- Oil Catch Can Questions
- Look at what this lady did to my brand new G with 28k
- In need of finding new 2jz gte non vvti engine with manual trans
- G35 coupe roof spoiler
- Art Pipes Question
- 03 valve cover ??? Can i use another year??
- Check Engine Light - Help
- Motordyne exhaust question
- Art pipes or mrev2 and spacer
- Need custom brake decals made
- Window Issue
- Need Help Please!
- Help!
- Camshaft sensor issue help!!!
- Engine Flooding
- Potential new G35 owner! Questions
- Raceland Coilovers ?
- 04 G35 coupe Driver headlight issue
- 2006 G35 coupe
- Body kits and styling
- Need Engine asap!
- Need to change my Motorydyne TDX2, but want to keep my ARTs
- front and rear camber kit
- Sunroof glass size --- Mine just flew off!
- Help Me - Spare Tire / 19" OEM / Donut - Who else needs a spare?
- Coupe 17" tire size oem
- VDC,Slip and Abs
- PLEASE HELP ME! Random Shaking (very random) from rear of car
- Overheating after thermostat replace
- Need a radiator replacement write up
- Seafoam pros/cons
- Brembo brake caliper O-ring
- G Wont Start
- 05 headlights very fogged.. replace or clean.?
- Wheel getting stiff
- Clicking noise on 6mt 2003 coupe
- looking for TP rear diffuser
- Working out the understeer issue, what worked for you?
- Smaller hoses
- Window Motor Replacement Question
- Uprades for transmission.
- Update on Invidia Gemini Exhaust and BC Coilovers
- Where can I find suspension and brake hardware?
- Helpppppppppp
- Need some help with diagnosis!!
- Possible Camshaft sensor gone
- Ecu
- Tire load rating???
- B&M Short Shifter Review..***NEW***
- Grinding noise do i have a bad clutch?
- Odd Interior lighting issue, HELP
- Ztube vs. CAI
- Windshield wipers problem
- Where can I get an oem lip?
- update on my car :)
- headlight damage
- camshaft sensor!!!
- Legit Rear bumper
- New purchase
- need help with wheels
- changing interior lights..
- Lowering Springs for 2003 G35 Coupe
- Radiator leak
- G35 left side (passenger) rattle over bumps...wtf?!
- Misfire Cyl 1
