- What is G35Driver's collective/expert opinion on northern cars?
- Lowest Lowering Springs
- Engine tick
- Question
- Front license plate Question ???
- Question for those you that have deadened doors with MLV
- Exhaust or Body Kit?
- Car shuts off after new tstat
- Long lasting brake pads plz
- Highway idling speed?
- Help!
- Why is not having a sunroof desirable to enthusiasts?
- Do I have a fuel gauge issue?
- Inven fitment
- vdc & slip problem
- Help identifying Front Lip
- 3rd brake light/spoiler light are out
- Need Help!? Air intake boot/tube
- G35 Engine Cooling Temp a little hot...I think
- Windshield washer fluid shoots off car?
- Please Help-No crank
- Hi guys - I'm new, and was hoping to get some help from the experts.
- Need help on what to get next!
- I need help with California Smog Emissions. :(
- $3000 for performance upgrades
- 03 mt/ 120k .... Maintenance ?
- xxr 526 tire size throwing vdc crazy
- Lower-front control arm ball joint.
- Low RPM During Idle After 5/16 Spacer Install
- best custom headlight/tail light maker
- Help please??? Shift issues
- bad ECU
- master switch from 06-07
- Oil Leak - NEED HELP IDENTIFYING A PART
- How to get up to speed quicker?
- whenever i slam the gas from standstill i get "slip"
- tips on how to remove dome light assembly from headliner
- Climate control issue? A/C always ON?
- Z-Tube w/ K&N drop in filter combo or 5/16 plenum spacer?
- New Here - Buying First G35!
- help transmission
- Bubbling Paint
- Takeda Short Ram Intake
- where to get motor re built?
- Oil leak- thoughts?
- G35 with AEM FIC
- Y Pipe Interchangeability?
- AC/Heat not working - not blowing any air
- caliper color
- Need Answers
- Brake pads
- HELP! VDC, slip and service engine soon lights on
- Need g35 lock and unlock GURU
- wifi obd2 for Iphone?
- Question on '05 headlights...yellow tint
- Want to buy this '05 G35... help?
- white smoke and burning of oil
- Motor swap
- Z Tube vs High Flow Intake Z Tube
- power seats don't work right
- What can I do to better my cars performance
- Need Help!
- The G drift build thread
- Steering controls not working
- NRG catch can fitting/hoses
- Tire Stretching, New Wheels, & Lowering
- Need New Engine For 2004 - How To Identify?
- Having some weird issues due to Cold Weather
- Help! How do I remove 04 a/t shift panel?
- New G35, couple questions on manual and bushings.
- Service: Who to take to?
- How to install shift boot on 04 auto coupe?
- New to Atlanta.
- A Very Different Horn Issue
- HID issues
- Rear Knuckle Bushings Replaceent Question
- dented my rear quarter panel: suggestions?
- Is my gas mileage really this bad or do I have a Fuel Guage issue
- Pictures:Athens Blue With Gold Rims
- What is this ?
- i think its time(replacing radiator)
- Please help !!!
- New!
- Generic headers (ebay headers)
- Led clearance strip
- Shifting From Neutral To Drive While Holding Gas Pedal
- Whirling sound at idle
- Start up squeak
- Synapse No Drone Resonators
- Changed thermostat and radiator still overheating 😩
- G35 totaled =/ Transplant into new G or?
- G35 coupe door lock problem or BCM
- Project Valve Cover Gaskets and Oil Catch Can Installation
- Nissan 350Z Brembo Caliper Swap
- 2007 G35 brake and wheels replace
- OEM Nav Install
- car wont start
- Lug nuts on oem rays
- Lemon back titles on K6 G35 coupes
- Coupe Driver seat hip bolster removal questions
