- 04-05 up rev engine swap?
- Steering affected for right turns
- Cigarette lighter memory stick
- -2 camber on stock camber arms
- anyone from oklahoma, need help finding/getting parts
- 04 g35 coupe steering issues
- Clicking/Clunking Suspension Noise While Braking
- G37s Akebono BBK
- Door locks/BCM not working... any ideas? And anyone in MD by chance?
- fender rolled/shaved questions
- S. Techs & Spacers Question
- Aftermarket OE style hood fitment
- Wide Body Kit Opinions/ Personal experience
- 2006 Coupe Headlights cheap
- infiniti dealership asking 1400$ for sensor repair(p1084) ?
- Left HID side went out again lol 💩💩
- Serious Brake Problem Help!
- 2006 Coupe Headlight $80?!?!
- Opinion on coilovers
- My G :)
- New Guy Needs some help
- G revving weird
- Front bumper hole trim piece help
- Wheel fitment question
- Car wont start. 2004 G35 coupe 6mt
- Is it normal for a 04 coupe
- need help asap... car wont move!!!!
- It rained last night, WTF did it do to my paint!??
- Installing remote starter - immobilizer bypass module?
- What matte color should I paint my car??
- G35 wont pass 4000 rpms
- Exhaust Hangers - Whats the trick!?!
- 06 MT coupe rocking
- Sandpaper to remove scratches on headlight?
- Fog light question
- $2k for initial mods?
- Exhaust.. Cost?
- Calling all Front Bumper experts
- premium fuel?
- Coupe Window Rain Deflectors?
- Would I need aftermarket camber arms for these specs?
- Aiming Headlights 2005 Coupe
- How to replace sunglass/map light and surround
- changing fuel gauge, anyone know which ohms resistance i need?
- Thinking about purchasing a NRG Steering Wheel
- '03 G35 Coupe Willow/Tan Interior Change? HELP!
- Myth or Real?
- Electrical problems need help!
- G35 Coupe Exhaust Question
- Emergency brake light flashing
- where to buy navigatin pocket
- KYB shocks part numbers for Coupe w/ Sport suspension
- interchangeable parts
- Rpm hangs
- Advice needed on twin turbo boost
- LED strips in headlights
- Radar
- where can u find this?
- Question About my G35 05
- Duckbill trunk
- Abs/Slip/VDC ALL on :(
- diff whine
- Almost crashed today, car performed perfectly
- Fiberglass help
- Cluster lights
- No Heat At Idle - 04 Coupe - System Bled
- minor paint issue... question
- New Technology thoughts
- Brakes - The whole shabang?
- Crashed G seat/airbag replacement
- Rear wheel bearing
- BCM (Body Control Module) Hyper Flash Modification help needed.
- rough start
- engine swap
- engine swap
- My brakes were smoking?
- TPMS & New Wheels
- Clutch Slip? Maybe?? Help?
- G35 Shocks/Struts. Need some advice!
- Test pipe nightmares
- R1
- 06 G35 Side Mirrors!
- Claims adjuster help!
- Muffler delete
- 03 g35 coupe bulbs
- Intermittent Starting Issue
- Am I to blame?
- 2004 G35 Coupe Coolant System Problem
- 2004 G35 Wheel & Tire Question
- Noise from the trunk [video]
- Power door lock issue?
- Best aftermarket Headlights?
- Money Shift :( Help!
- Anyone Here Using BlueTooth OBD-II Tool With Android App For Gauges/Codes?
- HIDs
- Armrest Broken. Any Help?
- Help with lug nut .. Wts the best lug nut ?
- nismo difuser
- Oil filter housing Gasket leak?
- Armrest broken. Any help?
