- Couple questions about the engine compartment from a noob
- Best Performing Aero
- Question regarding those with an Auto Transmission
- Castrol 0w40
- Offset questions
- License plate relocator?
- Motordyne?
- Fuel sending units cleaning
- Hi I'm new!! I got questions to gain knowledge
- 350Z Exhaust On G35 Coupe?
- just got my car back from getting transgo shift kit installed and wow!
- New G35 owner :)
- Need help with CAMBER DEGREE please (pics included)
- Headlight and foglight fuse
- windshield wipers not working !!!!
- 2006 Infiniti g35 coupe grinding sound
- oil on spark plugs
- 05 G35 Coupe Harsh Ride
- Nismo S tune exhaust w Artpipes anyone!?
- Sell my car as is or revert to stock?
- Factory under hood paint color G35 Coupe
- G35 with g37 19's spacers, stock suspension
- Overheating but not while idle or driving fast...
- New hids?
- Type of Bulb
- 5at transmission valve body swap
- Shaking/shuddering under slight acceleration at hightway speeds
- obd ii scanner linking error
- 350z nismo suspention on G35
- coil pack clear, does that mean my valve cover is ok?
- Anyone know what kind of lip this is?
- electrical malfunction...help?
- Recent Cali SMOG visit results.
- Diffuser
- 2005 coupe battery replacement
- Possible to Replace lower control arms without impact ?
- Does a real carbon fiber lip exist for the 06-07 sports bumper?
- Engine dress up! Need help!!
- After car wash, car feels loose and slippery.
- 2003 infinity g35 dent
- Driver side headlight issue
- Dash panel
- windshield sunscreen
- Valvoline Max Life ATF Aftermath
- Which rotors?
- g35 lsx swap kits...
- Window Misaligned?
- Major Oil Consumption Issue
- Tire Replacing Now Spacing is off.Rubbing Bad....Thoughts?
- VDC Off light.
- Automatic Transmission Maintanence Questions
- Question about front upper control arm/ steering knuckle
- Headlight Ballast Part & Replacement
- Sedan / coupe clock bezel
- Window Problems
- whining noise with cold start. belts replaced!
- Transporting problem
- Best website to get aftermarket headlights
- Coolant overflowing out of overflow tank? OVERHEATING!!!
- Ignition
- Is it worth investing?
- help turn signal problem.
- Slow Acceleration when parking/headlights on
- Replace transmission or replace trans valve body
- Water damage, need help!!
- Broken Clock Spring?
- New Petrol (Fuel) Cap
- Front Subframe Crossmember - 04 G35 Coupe Base
- 06 Projector - Random Wire?
- engine noise need some opinions, water pump?
- how to improve dead pedal?
- Front rattle, stops when I apply brakes
- 04 G35 Coupe exhaust sounds muffled at idle
- Sunroof chipped paint
- Tow hook with Nismo front bumper
- Rear End "Wiggle"
- What is this part called?
- Loud exhaust pop
- Spring Tune up & Trunk
- Steering problem.....
- Real or fake HKS Hi Power exhaust
- Just Dropped MY 06 G35 with SPC Camber does this look to low?
- New Color on my DG Coupe
- Low Speed/Coast feels like my tires are oval??
- Car chirp won't activate
- nismo v2 front lip - sports bumper
- 05 engine swap to a 03 G35
- Looking for a good tune for non rev up
- Little bad luck today, can this hood be repaired?
- VDC OFF & SLIP lights!
- 06 G35 coupe 6mt smart key...
- car won't start up after starter/battery changed, pls help
- G35 Good Body Kits? Help
- Opinions on black roofs
- Problem with A/F Ratio After ECU Reset
- Do i need a new LSD with 4.08 gears?
- How to tow with an Aftermarket Front Bumper? (With no cutouts)
- Stroker???
- Ticking/Clicking noise
- eibach sportline lowering springs
