- Still having bogging / shifting issues
- downshifting to a lower gear for pulling
- Weird brake noise issue.. help?
- Another screwed over oil consumption infiniti customer
- A/t5 tranny/ diff - is this normal ?
- Need Help ASAP!
- Limited Slip Dif Kill Switch
- OEM Trans fluid- DON'T BELIEVE THE HYPE!
- Engine swap kits
- New Compression Rods
- Bought 2006 G35 Coupe SC
- "Auto" Headlights Not Shutting Off?
- What kind of lip kit is this???
- looking for a interior AC/heater blower motor
- 03 G35 coupe (auto) Radiator cooling mods and etc help-opinons
- 04 G35 sport coupe
- Rear spoiler lips
- seatbelt connector
- Problem starting 04 G' with it starting...and then idle dropping and turning off
- Another lost G Coupe...
- 06 coupe seats in an 03?
- Spark plug recommendations
- I Need Help!!
- Headlight Question please help!
- Do you use Nissan AT Fluid?
- need help..is it a fender well or splash sheild?
- Engine dying after getting my JWT clutch and flywheel installed
- 2005 g35 coupe passenger seat stuck in recline position
- Favor to ask - measure something for me if you have stock suspension and wheels
- Pros and Cons on taking the resonator off.
- Clutch and gear box in the winter weather
- Just bought a 2004 black coupe looking for advice.
- Pulleys,clutch Disks, Engine Damper, Cooling Kits.
- Over heating problem.. need help ASAP
- G35 engine questions
- Dead Battery Concerns
- Thinking of selling G35 for Evolution x
- Recommendations for freight shippers?
- Help me win ride of the Month in Houston!! (: PLZ.......
- Which Engine do i have?
- car unstable on the highway
- Electrical wiring harnesses
- Our cars are still considered baller..
- camshaft and crankshaft sensor-check engine
- What to do what to do
- Was the investment worth it....?
- Looking to buy parts for my 05 g coupe
- What Should I Expect?
- Convince me to buy a g35!
- Window motor problemzzz
- Dead Battery lead to dome light/map lights and now guages and guage lights!
- Will these fit on my 04 coupe???
- engine shuts off
- Lube Locks and Hinges
- Passenger door problems
- Inner tie rod
- OEM Aero Kit Parts?
- new member & new to the g35 family. HELP!!
- Brakes, Tires, Rotors, and Spark plugs.
- PCM Backup circuit Malfunction
- Need a new radiator
- High mileage 2005 G35 Coupe
- 03 G35 Rev's up a little......
- Trunk Leak 05 coupe
- procedure to remove gas tank??
- G35 Shift Kit
- Grille badge swap
- Extended warranty costs
- WORKS VS-XX on an Athens blue coupe. stick to Burning black OR powdercoat it white?
- MT knob on an AT
- Timing gear replacement question?
- Part numbers
- New Guy intro and maintenance Q...
- Nismo bumper
- Service Engine Soon light coming on and off
- Concept One Wheels for G35 Coupe. Help us Decide on Finish
- Paint Chips spreading
- Purchasing Wheels and Tires
- Removing aluminum trim (in an 05)
- WFT intake off 03 03 Touring 350z
- Manual Transmission Gear Selector Question
- Ilovebodykits.com
- Mixing up the wide body?
- Need Some help Engine Knocking
- BC true coilover questions???
- G shut off while driving
- whats my next move?
- painting rims
- Charging system problem?
- anyone know what this sound is?
- Custom Exhaust
- need experienced advice
- Wanting to add a spoiler to my G
- Difference between coupe sport and non sport suspension?
- What tires do you have on your stock 19"s???
- new g35, having trouble finding nismo poly bumper
- Should I get it or not I need help ......
- Spare tire cover?
- Driver seat moving on it own???
- How reliable are lab results from engine oil/trans samples?
