- Rims that fit on 03 Coupe with brembo
- Converting OEM seats to Pull bar adjust . HELP
- Quick wieght question - front/ Rear bumper
- Odd noise coming from car....
- Help headlights
- Mishimoto Oil Cooler Kit
- Front Lower Steering Knuckle
- Interesting tire size on my G as of today.
- Need Clutch for 2004 coupe
- Leaking Front Wheel Knuckle
- Replacement Clear Signal Markers & Front Bumper Lip
- Vdc off slip ses and loss of power under wot
- Trunk issue, HELp!
- Coupe Lip Spoiler
- advice for a new clutch
- Need help diagnosing this engine noise *Vid Inside*
- Where to buy a replacement performance engine?
- Should I buy a JWT pop charger? Anything esle I should buy?
- Question
- Interior Door Handle Screw Cap/Cover
- Bang-for-the-buck exhaust mods before tune
- Severe Gas Smell Inside Cabin, Help!
- Look what the UPS man brought today.
- Avant Garde M510's. Should I?..
- Anyone know where to get Infiniti illuminated door sills?
- Crank Sensor
- Can anyone identify this noise?
- Question on G35 coupe SPC rear camber kit
- Impul or INGs side skirts
- Is this normal for positive battery connection?
- Mechanic gave me a heart attack this morning
- How do I remove the OEM spoiler?
- Cannot shift into any gears when cold / Loose clutch pedal
- Cold Start Up - Sputter
- Front Tire Wear - Inside tread
- Trunk Broken Into
- Heat Issues, Temp Gauge, ANY HELP APPRECIATED
- My new Rebuilt OC '05 G35
- CEL with MREV2 and plenum spacer
- 30mm spacers causing rubbing... Bad?
- HELP! How to remove screws?
- What do you think? Is this 2003 G35 fixable???
- Anyone tried this website for bumpers?
- Climate control issue
- Modification advice asap please!
- NEW!!! G35 Coupe Aluminum Bell Housing Panel
- Clutch upgrades?
- Newbie here need suggestion!!!
- Suspension Help??
- New 2004 G35 owner! Strange squeak and clunk sound
- Vertical Door Problems.
- Service engine soon? after oil change?
- downshift rev matching and using the clutch
- Changing HID Bulbs - 03 G35 Coupe
- Brakepad trouble
- Will these bulbs fit where my foglight bulb goes?
- Help with 03 G35 coupe
- AMS V1 CF Fitment
- is it necessary to resurface rotors when changing pads?
- Power Steering Pump Cap...Where to buy?
- Door Lock Actuator Compatibility? Sedan-Coupe (Air Fuel/Ratio Sensor Location?)
- Engine bay bolt dress up kits
- 04 g35 coupe bogging/stuttering
- Will this fit sport bumper?
- What the hell is rear air diffuser?
- If you drive your car hard
- Broken fuel door release
- Magnaflow x pipe
- engine spitting and sputtering
- Keep stock pressure plate or get an aftermarket Z1??
- Can your wheels get stolen if you're slammed?
- Is there a "Parts for Sale" forum (here) I can visit for some used body parts?
- Does this look like stock ride height?
- engine oil dipstick
- squealing start up?
- How do I turn on my fog lights without turning on headlights?
- smoke coming out of oil cap
- HKS Replicas
- 04 G35 coupe 5AT open diff or VLSD?
- P0304 / Valve cover leak
- Seat problems
- new here from texas
- '05 G35 Coupe Paddle Shifter Kit fit
- Test pipe install 3K rpm rattle?
- 07 G35 Hood question. Wind blew my hood back further then it should
- Sputtering after short block swap
- Help! How do I keep the fluid from draining out of the brake lines!?
- G35 Coupe Front Bumper Lip help
- '05 Rev-Up Engine Rebuild
- Exedy Clutches
- Thank goodness I purchased the extended warranty
- Throttle body coolant bypass? Needed or not
- Approx damage and will this be totalled?
- Repaint Bumper
- 2007 G coupe Exhaust ?
- 18" 7 Spoke Tires...
- New to the forum
- Buying MY second G35
- Can't see the front hood while driving
