- My G has been keyed
- Flat Black Or Keep LS color
- Could i possibly add anymore to this setup?
- 05 G35 stock Vs 2012 GTI stock
- My cam shaft position sensor
- Any other Mods that would be beneficial to my set-up?
- Sway Bar Question
- cnc short shifter knob removal
- 2007 350z transmission
- engine ecu question
- spectre short ram intake
- whats this problem suspension
- Slip / vdc off
- Missing Bolt
- Ngk spark plugs which one ?
- I ran over a raised manhole....!
- Problem with ebay engine dampener
- G35 Aftermarket trunks.
- Car dies on neutral when exiting highways
- Motordyne TDX2 ?'s
- Crashed my G35 today
- Repainting my G
- Get rid of an SRT for a G35?
- SS Brake Lines for OEM 2003 Calipers
- G35 vs Genesis 3.8
- Air Bag Light
- G35 Coupe gas mileage
- Side Molding
- gas cap broken.. Q?
- VQ35HR Motor swap question.
- Headlight Bulb/ 02 sensor/ Brake issue ADVICE!!!
- Damn u P0300 code
- Mass air flow sensor MAF ?
- 6th gear grinding
- Ac line relocation
- Trying To Go F/I
- Brake issue – this only happens 1st thing in the morning.
- Best place to get fenders
- Removing Temp / AC Display 2003 coupe ? How ?
- Coolant leaking from reservoir?
- Need advice on sticking clutch pedal
- I didnt know Infiniti offered the G35 with cloth interior
- Coupe power seat functions
- New to Forum..
- relocating battery to trunk
- Cipher cable question
- G35 Exhaust Mod
- Replacement Radiator Question..?
- Hesitation at higher RPM
- ANOTHER NOISE interior ?!
- Cost of Key Fob Replacement
- Strange AFM Problem
- New Member! Check This out!
- 2004 G35 coupe radio display issue
- Outter tire wear HELP ! (new member)
- New Member! - 07 Black G Coupe
- Long Time Member, First Time G Owner
- How do you remove side mirror glass
- K2 motor exhaust another hks replica??
- Engine light!!
- Pics w/ Nismo front and G Reddy skirts
- Gas mileage
- quick question about going in for oil consumption test.
- Got my g35 yesterday :)
- Body kit
- Driver side actuator is acting up...
- Help~please! climate controll
- First Car gonna be a G35 but help..
- Difference between coupe and sedan rear spoiler?
- Homelink with Condo Building Garage?
- Need Shop Recommendations for Vortech V3 install/tune in Alberta or Calgary
- Spacer size?
- G37 coupe air suspension fit in a 06 g coupe?
- another CL gem
- I've come to a conclusion !
- Just bought a DP G35
- Headers Input
- 2003 g coupe won't start
- ABS Self Check Sound
- New G owner, please explain
- Need some advice, looking for a G35 coupe
- Auto headlight
- just questions i couldnnt find the answer to
- High mileage
- Homemade invisichord for $2
- hid replacement bulb help
- Rear Tail / JDM Amber Lamps / NO BUMP
- 2 mufflers vs 1
- New 03 G35 coupe owner
- Any recommendations for a good G35 shop in the Los Angeles Area???
- Aftermarket DVD in 03 G35
- G35 clutch situation
- 6MT Reverse light fuse
- Nismo front, Greddy sides...
- YAY! Getting a G35!
- Adjusting Camber in the front
- Armor All Wipes Suck
- NEW 2005 G35 owner I want to mod! HELP!!
- Mystery piece in glove box
- Spark Plug Tube Seal
