- Clicking Noise
- Will CTS-V 4-pot brembo brake calipers fit the G
- JWT pop charger damage? (pics)
- question about JDM v35 auto tranny
- DO NOT BUY FROM Wheelsnext.com
- Which one is lower? Inven or Ait ings
- 2005 Coupe weird headlight issue
- Problems after installing cold air intake!
- 2006 g35 coupe automatic transmission no lag!
- new 2004 g35 coupe owner!! let me know what i should expected and advice welcome!!
- clutch/flywheel
- 2007 coupe a/c & heater fan not working intermittently
- Looking for a o4 g35 coupe jack
- Need a new clutch! Anything good for cheap? Also, Self Install????
- Motordyne XYZ + Stock Cats fitment question
- First feature of my G. Support Stunt Status!
- Drift???
- Genesis coupe v6 is in the Nissan family tree
- Fluid leak?
- Advice with buying G35 Coupe
- Is this Normal?
- Need Opinion on Rims
- Few questions about the 2005 5AT
- Selling the G, any ideas on what to get next?
- Leak in my Clutch Hose (Video) Pretty funny
- Help buying lug nuts
- Replacement Headlights
- another ebay lip
- 04 Coupe Transgo
- Clutch Recommendations
- camber help !!!
- 20" Rims - widths and offset suggestions?
- Had to say goodbye to the G today
- looking for a video a
- tranny mount replaced
- Dynod my 03 Vortech G- Fi experts please chime in
- can someone do me a free vin check?
- Introduction
- A/C Question/Problem: Not working in hot weather
- Any differences between coupe and sedan engines?
- plasti dip my wheel gold
- Spray paint noise...?
- OIl - Synthetic and Regular.. Combined?
- Lowered, does it affect the sway bar
- Bad alignment...? Or camber kit needed...?
- Chatter during acceleration
- G coupe sunroof same as G35 sedan?
- need recommendation on camber kit
- 4.08 to AT help
- Bent all 4 wheels
- G35 Reliability?
- Does the clock light up?
- Bad front hub assemblies, or something else?
- 05 Sport transmission issues?
- Dear killer G35 coupe questions...
- 2005 G35 Navigation Hack>Help
- question about brakes
- Filling Up With Gas Issues
- G37 Springs on a 2006 G35 Coupe
- Powder Coating Wheels.... Shop gives you loaners
- How do I remover driver side card holder
- hks rep x pipe
- HELP..Trunk Replaced Spoiler light not working
- TDX2 Owners who bought it new...
- Front licence plates?
- 3rd brake light on while headlights are on?
- iSimple Installation thread?
- Preventative Headlight Restoration???
- Got an 03-05 spoiler that you want to remove? (DIY)
- Best suspension for the best ride?
- Gas gauge problem
- G35 spoiler swap trunks
- Tach and Spedometer Dead?
- 07 Coupe - Side marker lights won't turn on
- Do fuel injectors increase HP?
- Motordyne Rolled or Flat tips
- Would this exhaust setup rasp ?
- Door Straps Not Working
- Problems After Double Din Install
- Speakers not working after changing radio to aftermarket
- Beautiful Sound
- Replacing Clutch
- Where Can I Get A New Throttle Body?
- Fuel Pump Question
- Error codes! Need new throttle body??
- Opinion on spoiler?
- Calipers cover????
- Best of the bad ideas?!
- Shifting to 2nd gear chokes....
- Opinion on paint
- New spark plugs after OC engine replacement?
- Performance chips, anyone ever use one? Also are sprint boosters worth it
- Black grill
- NSX over G35?
- Help?? Bumpyy ride on the G
- A/T light blinking on dash and car won't start
- Question about clutch
- New brakes recommendation
- FInally she comes to me
- help need some front and back brembo brake pads and rotors for under $400.
