- Newbie looking to pay for an engine swap
- Forced Induction Oil catch can help
- G35 74k...need tires
- LTB Superchargeed Sedan For Sale
- Slip and vdc off lights turn off and on
- G35 Coupe 2003 - Blend Door Actuator Knocking Noise Help
- lack of power.
- Body Kit Question
- A sad day ... my son crashed his 2005 G35 yesterday (1/7/21)...
- Selling G
- 2006 G35 sedan interior trim to g35 coupe 2004
- Catalytic Converter Replacement for CA car no longer in CA.
- 04 Coupe dies when started.
- Speedometer Damaged?
- Vdc off and slip
- 2006 G35 needs help!!! interchangeable years
- I need help
- Front upper control arm rubs on my tire.
- 03 170k blew engine. Worth?
- Cranks but wont start after short drives
- Need help with some a mod list
- Brembo brake clearnace
- Got Nav to stay up... but won't turn on
- California Smog check, can I pass?
- G35 Grill
- Should I buy a 2007 g35 coupe with a broken head gasket???
- Window tinting
- Low coast brake solenoid fix - code P1772 - G35 coupe
- Need a picture of the gas fill neck
- Has anyone corner balanced their G?
- Help no crank no start
- Does anyone know what this is called?
- Help I’m stuck
- Heated seat question
- Need Help! Radio not playing any sound
- Engine ticking from top end drivers side
- Changed spark plugs, old came out gapped .075, cylinder 3 plug well flooded with oil?
- Chargespeed Rear or Nismo Diffuser on Black Coupe
- Valve cover question
- Akebono Brake pad fitment
- LS swap into a 2005 Infinity G35 Coupe
- Oil Cooler assembly question
- Need Help technical Issue FBO cammed G35
- Looking for seat covers - 04 Infiniti g35 coupe
- 06 coupe 6mt No acceleration in gear
- Clutch problem.... No forward of back... please help..
- Aftermarket Headlights
- TorqAmp worth it for 07 G35
- Rear suspension too low.
- P0300 Code SES Light Gone?
- transmission pan gasket leaking
- Inexpensive low profile ramps for coupe to have access for a service jack
- Temporary exaust
- Offset
- Reliable engine source
- I need some help with exhaust setup.
- Looking to drop G slightly. Springs/shocks or coilovers?
- Need help with fitment
- High pitched buzzing sound coming from under the rear of my G
- Suspension? Wheel bearing?
- Inner tire wear front camber?
- Striped out the crank position sensor bolt hole.
- NGK Iridium sparkplugs
- 06 Projector New/Interesting Problem
- Spec d headlights Not working?
- G35 stitch Steering Wheel cover option
- Autobody question
- G35 engine shut off at drive thru.
- Climate Control Buttons aren't backlit when headlights are on?
- Gorilla Friend tore off my shift knob, anyone have experience with this?
- 2004 g35 coupe coolant lower reservoir help
- Transmission Swap HELP PLEASE
- Help, I had to cut my ignition coil wires and don’t remember how they went
- 10in - 12inch Radio for 05 G35 Coupe ??? Has anyone found/installed one?
- windows malfunction
- O2 Sensor Help!
- Suspension questions.
- Sawtooth like metal shavings in oilpan, HELP!!
- bank 1 sensor 2 help
- Rear Bumper for Black Obsidian Coupe
- VDC Sliding
- No brake pressure
- Finally had a window lift motor go south...
- FIRST MODS (dilemma)
- G35 UpRev Tune
- B1054 Code from Hell
- Help!
- Help! P1283!!
- Brake fluid recommendation for 2005 6MT
- G35 Shocks and ride
- Bleeding Clutch That Has No Pressure
- Engine Bay to Fuse Box Wiring Harness
- Is this an oil cooler o ring leak?
- Sunroof dead
- Do I need a tune??
- Overheating and leaking coolant
- 2003 G35 CANBUS LOW tap - where?
- Did the 2007 coupes come with RWS
- 06' G35 Coupe
- p0128 assistance
