- 05' coupe: Is it okay to jack more than 1 wheel at a time?
- Compression Rod weight ??
- Help with these wheels and a little photoshop
- Coolant valve closed and Osiris tune
- wanna replace front bumper,any suggestion?
- Tein Basic coilovers... bouncy ride
- Reasons why you don't like driving people in your G
- Trunk Leak - rubber grommet
- Somethin' screechin'
- Compression Rod Replacement
- anyone in charlotte NC area with motordyne exhaust or HKS?
- 03 coupe rear sways
- What was your first mod?
- Some newer pics - Who makes those lights???
- How would these wheels look?
- grounding kit?
- Engine Questions
- Changed my PS fluid. (Pic)
- CAI or Z-Tube/popcharger?
- My G is dying :(
- Tuner Shop?
- Part number for clock trim?
- 474 RWHP G35 Coupe
- traction upgrades
- What body is recommended for track setup
- Best place to order a fender???
- G35 handling
- Seat Heater Switch Light
- Engine squeaking noise after oil change (HELP!)
- Interior Door Pull
- Eyelids the cheaper way
- i bought a g35 coupe just now,but many things have to repaire
- Brembo Caliper Bolt Size?
- Just installed 06 projectors... disable drl?
- Looking for real recommendations for new summer wheels.
- Rear Wheel Bearings After 47,000 Miles?
- Big problem! Help!
- How much should I pay for a bumper?
- Most comfortable Coilovers that can 'slam' your car with?
- Belts
- Please Help Gauge Cluster Light And Radio Not Working
- What are some good looking cheap black 18' rims
- spray paint rims
- How to adjust windshield washer sprayers?
- Unknown switch inside center compartment? Pics inside
- inner thread wear
- Not shift to 5th gear in Automatic
- Please Help Dash Lights And Radio Went Out
- 06 G35 6MT Starting Problems
- Buying a G35 Coupe...what would you guys do here?
- Paint Housing
- How much have you spent on Suspension?
- GT-Spec 4 Point Chassis Brace
- Splash Shield
- How to remove and tint your tail lights "gtr" style.
- Anyone with a Injen cold air intake( I need a sticker number for smog)
- Road noise
- Idle Dipping when in park or neutral.
- Forza 4
- Changing the leather area beside the shift knob
- Turbo suggestions
- G35 OEM Nismo body kit?
- Tire advice please. new tire needed ASAP
- Any good tuner shops in Baltimore-MD area?
- Emission Problem/ High RPMs ???????
- free spoiler
- Scratch Repair Help?!
- New guy here.
- Spoiler..
- Zinik Minardi or Avarus Av3?
- is it worth it? 04 g35 for 8 grand?
- Part of Headlight and Sidemarker out. Help pls.
- mini shoot with the ls. come take a look!
- From Go to Low.. Gotta Question For My Fellow Stancers...
- Tried ECU reset, now car only clicks
- Plenum spacer
- Need your help on rpm needle issue
- spoiler installation anyone?
- 03 coupe security system malfunction???
- What Part Number/Name is this?
- Spotted silver G, West Hartford, CT
- Which Front Bumper is this?
- GPS install question
- Whats this piece?
- stock suspension question
- Looking to buy a Topspeed Pro 1 Exhaust!
- Can someone identify this car?
- Deal or No deal?
- Best quality and most accurate gauges,at a fair price?
- 03 vs 06
- battery relocation ?
- Swapping head units
- Advice please
- Driver side Main Power Window Switch is out...what can i do?
- 2004 g35 coupe help
- LED door light!
- G's rear wiggling at freeway+ speeds
- Next Mod Big brake kit or coilovers?
- To clarify... all 04.5+ Z's are revised?
