View Full Version : Brakes & Suspension
- NEX coilovers???
- Squeaking/dangling chain noise from rear?
- g35 coupe tire alignment wear - frustrated HELP
- Yay!! New comression rods!!
- First Gen Eibachs springs fit 2nd gen sedans?
- Struts/Shocks for 2003 G35 Sedan
- Clicking noise from the rear because the car is too low!?
- Really Noob Wheel Question
- Rotors
- need suspension suggestions please!
- Please Help: Squeaking Brakes!
- sedan spring question
- Rumbling noises and shakes
- Blank, Slotted, X-Drilled, or Slotted/X-drilled....read this
- Coilovers for 07-08 g35 sedans
- Brakes Squeaking!!
- One more question before I buy...
- Akebono brake pads made big inmprovement in stopping power
- Lowering on 18's and 20's
- ...and parts start showing up...
- uneven drop, what springs to get for fronts?
- Tokico Hps struts installed
- ! camber question!
- problem please help!!!
- 04 G Coupe with 06 G Coupe Sport Suspension Spring Question
- BBK question
- brembo brake
- Bushings, cracked
- 7500 miles in and Warning on speedometer?
- 56k beware!! s-techs before and after pics..with a little extras
- Do Big Brake Kits work?
- Why does my car feel so sloppy compared to other cars??
- Z h-techs on G sedan
- Car shudders and vibrates while braking at speeds above 70
- GTSpec Front tie bar and splash guard
- question about cutting springs
- best pads for oem brakes??
- Help: Brake Pads
- Brake Fluid
- GTSPEC/Circuit Sports under bars & alignment
- Tein H-Tech Springs, camber kit?
- So, my front springs are cracked / cracking.
- help pls, problem with rear suspension
- Time to change brake pads, but which ones?
- Something wrong w/ brakes HELP
- Brake Fluid
- Spring Install?
- New suspension for Stock 2003 Sedan
- OEM or Hawk pads
- G35 suspension question (LOWERED on TEIN SPRINGS)
- 350z Tein S-techs or Tanabe GF-210...not DF-210's
- Will I rub...
- I am thinking of lowering my car. Help
- Lowered on 20's
- GTSPEC braces
- Fitment of Richie (NRG) Strut Bar on Sedan?
- Need Help ASAP Installing Front Stillen Sway Bars
- Identify this part Please
- Endless 12pot BBK!!
- Brake Rotor Shims - What are they for? How do they work?
- Compression rod / bushing - warranty coverage???
- 2007 /2008 350z suspension on my G
- Anyone Drop on stock 17's?
- Need shocks with GF210's?
- Installing Coilovers
- Tein EDFC strut bracket kit
- Loud Thud Coming From Rear
- Very Loud Braking Noies at Lower Speeds?
- dampening adjustment knob extension
- Where do you usually cut rotors? at what price?
- changes in springs among the coupes?
- 350z f/r sways + springs
- 04 Standard Front Brake Install - Wrench Sizes?
- stiff rear shocks/ more travel?
- Question for those who lowered their cars
- Tein EDFC on rear shocks
- Alignment question
- $130 Labor to change brake pads... overpriced?
- Got Alignment done Do i need a camber kit?
- Tein coilover question
- Need ROTOR And Brake Pad installation instructions!!!
- Stock shocks on 350z h or s techs?
- Looking for a Drop and Spacers on Stock 18 - Serengeti Sand - Advise please
- Best Brake Setup
- Do 2005 G35 Coupe MT, have 06 front brake pads?
- Brake Components
- DropZone Springs
- Results of alignment after 350Z/G35c springs
- need help with suspension component to repair
- What is the best setup for me?
- Replacing rear lower arms???
- Which shocks?
- How does lowering effect taking corners?
- Outer tire wear? Pos. Camber or...??
- Powder Coating Calipers?
- EEEEEEEEEEEEEEEnd Link Questionssssssssssss
- Coupe brakes on a sedan......
- Teaser
- Different Springs between the years on the coupe?
