View Full Version : Brakes & Suspension
- Buzzing in the engine bay while off?
- Brakes Squeeling, A quick ?
- Recommended Brakes for a 2005 G35x
- Ok G35 H-Tech Owners chime in!
- Which pads? Hawks, EBC, Akebono, Ect
- Wondering if this is a good price?
- Just installed Cross drilled/Slotted Rotors and Posi Quiet Pads: QUESTIONS
- Props to SPL customer service!
- Review: Sway Bars by Top Speed Auto
- Brake Squealing
- Damn Tire Hop
- newbe looking for help with d2 coilovers
- Help! VSC locked up my brakes
- Just lowered, where to go for alignment
- Possible DIY fix for clunky rear endlinks w/sway bars
- Spring question
- Ae eibach sway bars any good?
- Suspension HELP
- Can anyone give me some good advice?
- Need advices on suspwnsion setup
- Rear caliper piston failure?
- Question about 'dropping on Zsprings'
- RAS + Aftermarket sways = possible?
- question about rolling fenders
- anybody running 350z Tokico hp?
- H-Techs on a Coupe...........
- G35 vs G35 Sport
- Brakes not braking!!!
- Strange Problem
- occasional grinding on non brembo
- Question with brake change! quick one!
- What springs should I get?
- MR street series coilovers
- do you recommend extensions for rear coilovers?
- Wtf Is This?
- need help finding camber kits!
- What Spring to use?
- Control Arm / Braking / Rattling / Whatever
- TUMP sound from Front Suspension
- compression rod creaking noise!
- Pads and Rotors?
- Did you cut bump stops when you lowered your G35????
- New to an Infiniti and have ?s about suspension
- Weird noise/vibration in the car when i turn right
- What paint to use on Rotors??
- Edumacate me :)
- I just bought used stock brembos. I want to upgrade lines, fluid, pads
- KYB GR-2 vs. Tokico HP
- help with suspension
- Can't get the rear rotors off!
- Anyone know how to get ahold of Soad?
- 350evo Sway Bar Settings
- Pics with Tein Basics with Tein recommended height?
- SPC rear camber and toe kit
- OEM Parts List for Tein Basics installation
- will this get in the way, when i lower the car?
- G35coupe Pictures of Z Tein H-tech and G S-tech!!!
- help bottoming out all the time what should i get?
- Please help regarding brakes
- what finish should I get
- Weird Brake Feel
- DIY: Fixing excessive front brake squeal
- lowering with 350z swift springs, will this tire/offset set up fit?
- Ikeya Formula Arms
- Need brake pads. Recommended source?
- Rays Red Long Lugs, Short Lugs, or neither?
- Adjustable toe arm and camber kit?
- Stoptech Stage 2
- a lil help with springs
- Why would my Front end link be rubbing on my shock!
- Stupid question - G35C A/T brakes
- Stillen Front Strut Tower
- G35 Brake Fluid
- 07 Coupe Springs Fit?
- What brakes and rotors to get?
- pulse in my brake pedal
- Shock Question
- anbody have some helpful hints on switching calipers
- I have a 2003 AT coupe and i want brembos from a 2003 MT
- Where Could I get my Rotors Painted
- Alignment Report
- What Springs to get for IP on GTC's
- my ABS/Slip/VDC lights went on after changing my wheel hub,, Anyone know whats wrong?
- G35x With H&r Sport Spring
- Unrevised SPC A Arms
- What lowering kit should i install?
- best OEM rotors (brembos)????
- Brake help?
- Spacers and VDC
- questions on Bc racing (installation)
- Stock black rims on dg coupe
- Let's see your drop!!
- Bbk
- DG sedan with Time Attack Axis Hiros
- Silver Coupe with Time Attack Tenzos
- G35 coupe and G35 sedan same?
- VENDORS - Where's the BBS love?
- Best Rear Camber Kit for the $$
- Solid VDC, ABS, and SLIP light on
- AIRFORCE suspension...ever heard of it??
