- 03 to 06+ Headlamp
- 06 Sedan headlight housings (aftermarket)
- Rear Spoiler Brake Light Replacement
- KP Technologies Fog Light Module OFFICIALLY works on M45; and possibly G37!
- HELP!!!!! Metal Bracket holding 06 Projectors Ballast
- LED headlight project.
- Headlights different intensities?
- Projector Issue
- LEDS on with headlights/Parking Lights
- New lights teaser
- lights not working need help with wiring
- aftermarket ballast?
- headlight housing boo-boos
- which bulbs to use for clock light? also side markers light are not working
- Lighting opinions
- headlight out plze help
- Driverside bulb burned Out-Not covered under warranty
- Window lock button bulb on arm rest - Replacable???
- Need help with HID bulbs
- My led corner light builds from past few years
- Help with H1 Hid install on 03 sedan
- need help with 06 light bulb low beam removal
- installing third brake light?
- DIY: 05/06 Tail light swap
- Ballasts question...
- Something you all might find interesting about the headlight bulbs
- Headlight Lens Repair Question
- philips ultinon hid bulbs
- replacing the stock fog lights in 04 sedan?
- Strange issue with LED interior lights
- City/Daylight Running lights
- Anyone with DASHZ Headlights?
- Recall 06 headlight part number
- 2003 HID headlight problem/question, please help!
- upgrading to 06 projectors but i don't have the old headllights
- DIY: Adding/Fixing 3rd Brake Light if you went Spoilerless/ DoriLuxe/ Strafe Trunk
- V-leds LED strip in my trunk
- GI Gauging Interest: the FIRST After-Market Projector Headlight for G35 Coupe
- Morimoto Mini Projectors h1/d2s
- Taillight repair??
- philips 6000k bulbs vs other brands
- Flickering Issue
- 06-projector Fog light aiming question
- 2004 Coupe Headlight replacements
- Philips Colormatch Bulbs
- Nokya Hyper Yellow bulbs on sale (40-50%)
- Coupe vs Sedan headlight assembly
- Cheap projectors?
- Question regarding accident !
- Led Dome lights
- Has anyone tried these????
- Headlight is effed up...
- Passenger Low beam out
- Gauge Cluster LED Kits on Ebay?
- 2006 Headlights
- Radio buttons not lighting up
- 03-05 g35 coupe headlights vs 06-07 g35 coupe headlight?
- My Quad Projector build Thread
- Xenon ballast with Halogen assembly?
- how to change the door light?
- Every light modded + seriously unique hl's and tails
- Help!! Map Lights Malfunctioning
- 2500K Side Markers?
- Question about Quad Projector retrofit
- Rear Driving lights and tag light out, help!!!
- E46 bi xenon retrofit?
- Post your head lamp/fog set ups!!!
- JDM lights
- 05-06 Sedan Headlams on 2003 Sedan
- autozone LED strip
- HID wiring swap
- 06-07 coupe city lights are out...
- Need help! Is there a DIY to install DRL
- Pics of newly-installed LED halo's.
- 2004 Coupe conversion to 06-07 projectors
- Aftermarket ebay headlight housings?
- Day running lights problem...
- Coupe Rear Tail Light LED Specs
- Will these Headlights work with 04 Sedan?
- DIY Paint your headlights my ***
- Dome light issues
- Headlights?
- Canadian coupes upgrading to projector headlights will lose DRL?
- BlueBatMobile Overlays
- Anyone changed light surrounding the ignition???
- Tail Light / Trunk Lip Brake Light Wiring
- LED project begins
- 03G35 Sedan
- 06 look for 04 headlights?
- Coupe projectors as sedan fog/high
- Interior Map Light Problem
- Headlight question..
- strange interior lighting issue
- Anyone local to Richmond, VA/Long Island wanting their sedan headlights retrofitted?
- Side Marker ( On the Headlight ) Not Working
- Headlights Painted
- Interior, Clock, and Gauge cluster LED conversion
- Reversing blacked out headlights/tail lights
- Blinker mod, is it safe?
- 03-05 Headlight Clearance Strip Q.
