- Best way for "under-seat" LED mod?
- Headlight HID bulb change
- It begins... Projector Retrofit Madness! (56k = No way!)
- Led/smd strip in clearance strip
- headlight not working
- '04 G35 Coupe - Cloudy Headlight Covers
- Replacing trunk light with 24 led board
- What size LED's are in the bottom of our doors and in our overhead lighting?
- Painted headlights - need help
- need help
- Reliability of AAC Oracles?
- quad projector mod and sidemarker mod(fix)
- Which 6000k HIDs should I get?
- How can I tell a HID bulb is new & unused?!
- AAC - Oracle Halo Kit
- Another gauge cluster LED change, white and blue
- Deal on 06+ Projector headlights
- Ballast question
- Wanna copy another members sedan tail lights...
- Project IBP: Projector Headlight Modding With A New Twist!
- New headlights for my 03' (newbie)
- Headlight switch: order of lights
- Convert eBay 03/04 Headlights to OEM HID
- Rear side lights???.....
- 7443 sockets from ebay?
- q45 projectors
- DIY LED headlight thread
- 8500k Bulbs?
- Headlight no longer blue
- interior lights issue
- For all Retro Fitters
- Baking headlights
- projector question
- Side Markers not working
- opinions for next project :)
- map lights constantly on
- Don't know which one I need...
- My HID bulb burned out. Not sure which I should order. Need help =/
- LED & headlight experts gather! Opinions and help needed fast!
- Projector Upgrade
- Hid-d2r
- thought this was interesting
- Map/dome light replacement with LED
- 06-07 headlights with led bulbs?
- Interior lights not working :(
- Replace OEM HID kit w/ Aftermarket HID kit.
- LED headlight mod for Canadian spec?
- Map/Dome lights not the same output
- Color of LEDs question
- City/Parking Light
- help please!!!!!!
- led strips around projector lens
- will 04 sedan headlight lens fit a 04 coupe? or does anyone have passenger side lens
- Mt.Fuji on High Beam!?!
- G35 Headlights Halogen vs Xenon
- HID problems
- Where to find a new Nav knob
- Location of the BCM in 2003 G35 Sedan?
- Bottom Door Light replacement
- Changing my modded healights. Before and After pics
- Step lights aren't working
- Replaced Map Lights with LEDs.. STILL ON WHEN OFF?!?!
- Good place for clear corners?
- What kind of plastic are the tail lights covers made out of?
- Matte or Gloss Black Clear Corners?
- possible to have 03-04 sedan turn signal to stay on and still signal
- Sedan Clear Corner Installs
- hid blubs
- High beam bulb
- Having my sedan headlights modified
- new project 05 g35 plus projector and paint
- Compare these 2 LEDS for License Plate
- Help!! How do you into the ashtray to connect my l.e.d.
- HID in Fogs HighBeams
- Abou Headlight change/ HID
- Are These Worth It?
- I want fogs seperate
- possible to make outer rings stay on constantly
- quick question about changin my bulbs..
- Need help on fog light fuse
- where can i order an OEM 3rd brake light for g35 coupe?
- Where can i find led headlights fixture 2006 g35x
- 04 reflectors to 06 projectors... city lights question.
- Seal Packing for Rear Combination Lamp
- How to aim headlights?
- Light up the Infiniti Emblem on Steering Wheel
- headlight help!!!
- So just how RICE is lighting up your intercooler with LEDs!
- Problem with my doom lights??
- Coupe 3rd brake light moved
- HID Replacement Bulbs
- New projectors. Disappointed?
- Headlights
- 8k hid replacement-yes or no?
- anyone got cin city headlights on their g ?
- Rear Lamp assembly clip question
- what size socket needed to remove tail lights on g35 coupe?
- G35 headlight ?
- LED Clock Lighting Problem / Question
- Flickering Left HID Headlight
