- what type of load resistors
- '04 coupe headlight replacement ?
- Started my Quad Project
- 06 Headlight Question
- How Do I Make My 2004 G35 fog lights beomce HID
- HID problem
- Anyone used those fake Xenon HID Halogens?
- Tip for anyone doing front LED blinkers w/ load resistors
- i want leds under the hood
- city light question
- Help! Water inside headlight! HID Ballast fried?
- Will these fit 2006 Headlamps?
- 2003 G35:Headlight Replacement OEM Bulb Question
- Question on Auto light feature on a 2004 G Sedan
- replacing clearance lights
- Fog Lights Still DULL Yellow
- relay in controller box
- What happens if you put D2S bulbs in your D2R housing?
- Headlight question
- Has anyone tried this?
- what size bulb goes in there! picture to show!
- HID bulb testing?
- Tinting taillights...
- WTF?! ONE of my headlight turned pure purple WHY?!
- Audi leds strips
- Headlights replacement?
- which bulbs??
- Help....My Hazard Lights Don't Work!!
- Passenger side stock HID
- What's the dif?
- Changing overhead bulbs
- What just happened? ****!
- license plate bulb
- License plate bulb help
- HID kit recommendation?
- Fog Light Assistance Needed - OEM
- projector install
- Project: LED MODS (part3) Finished Gauge Cluster
- Possible to disconnect part of the tail light?
- Quick question on led opinion.
- Painting Headlight Housing
- Light Expert - Which Silicon should I get to re-shield my headlight?
- Any local want to give a brother a hand?
- 06 projector headlight fog light help
- HID Ballast swap...
- PIAA'S, LUMINICS, NOKIA'S Bulbs?
- How to replace 04 coupe headlight bulb
- 06 Headlights
- Bulb replacement for ignition ring
- How would these work in clearance strip?
- Looking for help with the projector screw.
- Bulbs.com
- Headlight fuse location!!!! Help please
- 06-07 Projectors in 03-05 Housing
- Putting LED Bulbs in Clearance Light
- Ouiespu HID kit?
- installed 07 headlights and HID fogs 56K NoNo!
- replacing fog bulb
- plz help dome/map lights
- wiring help for clearence led in PROJECTOR housing
- what type of bulb do i need?
- Custom Headlights
- Which light is which?
- Rear side marker bulbs are out
- First mod help:Interior LED lighting!
- LED Help!!
- Best Clear Corner Led's
- Left Blinker trippin HELP!!!
- HeadLight Bulb ?
- 04 headlights don't match?!?!
- I this a good deal...?
- Painting housing question.
- HID bulb issue! blub or ballast?
- Looking to upgrade: Hir bulbs anyone?
- Courtesy Lights Not Working...
- Clock LED Implementation
- need help on kptech foglight module
- Pic request: Anyone have fog lightsYellow (2500k) night shot?
- 2006 headlights on a 2004 coupe
- New halo/demon eye modification
- Custom LED headlights
- Lighting issues
- New lighting all around
- Left headlight projector not turning on after carwash.
- clearcorners.com sidemarkers
- 06-07 headlight problem (drivers side)
- Arg...bad ballast perhaps?
- G37 Bi-Xenon Projectors question..
- 06-07 Projectors w/ black housing
- how to tell if i have Factory HID's or not?
- Problem with headlights
- help with lighting problem
- 2006 Coupe Tail Light Problem
- White turn signal bulbs + fog lights
- Low Beam Problem
- Tapping into switched power in the cabin
- 05 with projectors... finally
- 2008 G35 Headlight bulbs
- Wiring help
- Projector project......Feel free to help!
