- resealing headlights
- Xentec HID Kit
- Check out my led light =]
- How to DIY replace HID light blub?
- Problem removing third brake light
- tryin to install fog lights on lower grill..which fogs?
- 04/05 lights for 03 sedan???
- Daytime Running Lights Help Needed
- HID on 04?
- How long is my headlight supposed to last?
- domelights out?
- HID retrofit kits
- "Projector" turn signal teaser
- dealer instill 06 headlights for $187
- lighting question
- Easiest way to replace bulbs?
- Anyone other sedans hate their incandescent turn signal bulbs?
- Headlight switch mod?
- Help with 06 projector headlight disassembly
- Want to buy projectors for my bf's valentines day gift! please help=]
- ? 07 sedan headlight
- philips ds2 4300k or 5000k?
- H1's??
- Bright lights make it right.....
- turn signal messed up
- 2005 G35 Sedan low beam bulb question..??
- liscense plate lights
- 06 headlight projector headlight question
- help..
- Moisture in headlights....
- Rear Turn Signal LEDs (7440) - What's good?
- '06 Projectors Cutoff -- Weak to anyone?
- LED Bumper clear corner lense project
- Rear Side Marker
- Piaa or Phillips?
- Anyone sent their headlights to Advanced Automotive Concepts?
- How 2 Change Blinker Lights in Headlight???
- Need some help comparing
- Upgrade to 06 projector headlights or just upgrade the bulbs?
- aiming fog lights??!
- Help with FOG LIGHT/HIGHBEAM?
- 06 Lighting help
- 04 Gauge Cluster Blue - Need to trade
- Lighting Question on upgrading to 06 lights.
- Changing Light help
- Map lights
- 2006 head lights question help please!!!
- V-LEDS ftw???
- headlight helppp
- quick help d2r and d2s bulb
- 2.5" clear lens - ebay
- difference between hid bulb brands?
- 06 g35 headlight
- H.I.D. Upgrade Selection
- Confused, bulbs for headlights 04 sedan
- Auto headlights
- Anyone tried/seen Sylvania Silverstar Ultra's?
- Disappointed with V-Leds.com and superbrightleds - recommend some other good bulbs
- Exterior Lighting Opinion
- will these LEDs work?
- 06 sedan - headlights not yellow but kinda foggy
- Clear Bra on Projector Headlamps?
- Interior Light Dont Work Need Help
- How long before the headlights start turning yellow?
- 04 Headlight Retro Fit
- Looking for exterior lighting like IS300
- Noob Question.
- 06 tail light cover
- quick question about 06 headlights
- Tail Light Harness Clip
- Fog lights no worky!
- My Quad Projector Retrofit
- My $60 HIDs
- H1 Luminics 5150k Ultra White
- G35 HID lights?
- 05 to 06 headlight swap
- Light bulb replacement question, I need help
- Can I transfer my headlight lenses
- Blacklights for the G
- need help choosing leds
- Another bulb/led question
- 2003 G35 Sedan Headlight Replacements - state of the industry? Big ups to the OGs ;)
- Water In My Headlight =( Please Help!
- Did I blow a fuse?
- 04 sedan brake lights blink
- 05-06 sedan tail lights aftermarket replacment
- HeadLight Ballasts
- Fog light output question ???
- headlights problem..please help
- OEM Fog lights info ???
- What Are The Best Back Up Lights?
- O6' retrofit help???...
- City Light Question
- Luminics h1 JDM yellow fogs???
- US to JDM/Euro help ____/----__/---- to ----\___----\___
- 03 Sedan - eBay Headlight Question
- Changing the Step / Courtesy Light
- 6000k vs. 8000k
- Headlight Modifier?
- Ballast went out.. how to replace
