- Need some advice: Parking lights are not on
- LED Corner/Blinker Project Completed
- side markers not working
- leds in 06 city lights
- HID Kit
- hi beam bulb replacement question
- Need Help: Headliner & Dome Light
- Halogen Fog replacement
- Sedan Lighting/Housing Question
- 06 Headlight upgrade question
- 04 5AT shifter light.
- Attn light gurus
- quick question on where bulbs can be found
- room lamp LEDs leddomelight.com
- Headlight bulb is fine still not working
- HID colors?
- G35 fog lights (05+) - which to get?
- Need VERY specific help with external LED replacements
- 06 projector housing
- Head Light Mod Help
- Head Light Mod ?
- Custom guage cluster finally done!
- Wedge Bulbs
- Changing fog light, main light, hi-beams and side strip?
- taking the headlight apart???
- 8000k or 6000k d2r hid bulbs
- how to remove the light under the door
- M35 Headlight retrofit
- HID Question
- 3.5 hours labour* but is worth it^^"
- Rice or no
- Project Prototype
- LED illuminated door lights
- quick question about these headlights
- door light wont work!
- kenstyle fog bulb size?
- upgrading JDM 06 taillights
- Load Resistors or Electronic LED Flashers?
- What's the part number for the Analog clock chip?
- A couple HID questions...
- Where can I...
- Color matched headlights - Twilight Blue
- "INFINITI" Third Brake Light Upgrade
- Cool Trick
- Look what I found!!
- LED Clear Corner+CCFL,LED Interior [Pics]
- clear blinkers
- Anyone install BAT's tail light overlays
- demon eyes
- My 06 Projectors in my 04. Did I get a good deal?
- changing door lights??
- LED's please help
- Installing halo rings
- modified 06 projectors by littlodevil with pictures
- Sequential LED Rear Turn Signal
- Has anyone tried these jdm bulbs
- HID Headlight Buld Replacement?
- Best D2S Bulbs ??????
- '06 headlights w/bulbs for cheap
- I just bought these, is it a good deal?
- 06 headlight Question..:confused:
- Turn signal bulbs
- fog light hell.
- NRG Optics H4 Yellow Fogs installed
- white leds legal?
- Weird Problem - Parking Lights Wont Turn Off
- Headlight question
- Clearance lights?
- help for headlight installation.
- Check out these prices for $2 LED's.
- fog lights won't work
- New G owner just a quick question.
- Trying to change bulbs
- VLED High Power
- Anyone need TSX projectors for Retro?
- Latest Tailight Mod
- 06 headlights
- v-leds vs matrix 5-leds
- Replacing all 4 bulbs, quick way?
- trying to get better lights..
- Seal Packing
- Are D2C blubs ok to use instead of D2R?
- matching corners and clearance strip
- Routing outside sideskirt wires into the cabin
- Tail Light Blinker mod?
- How do you install headlights? easy?
- 06 headlight 8k vs. 6k
- Where can i get Custome LED side marker?
- LED under glove box/steering wheel help
- Sick Fogs! Where to buy?
- Orange CCFL
- philip 6000k
- Where can I get inexpensive clears that dont leak
- Is yellow good for fog?
- Painting headlights on 04 Sedan
- Changing Int Lights To Led's
- where can i order led's?
- hgtr2 overlays
- Overlays in Mass
