- Interested UPGRADING your HID's and Lights?
- under the door lights
- Clear amber bulbs
- clearance lights
- Clearance bulbs
- Changing Headlights and Fogs.. i'm so lost.
- Gauges light option
- trouble with Fog Lamps
- Help Headlight one side brighter then other
- H.I.D FOG LIGHTS
- What are those tiny little lights for??
- Installing Front Vertical strip lights
- Fog/Driving lights behind the lower grills
- Front blinkers...
- Clear corners with orange bulbs ugly?
- Wait time on Clear Corners
- Colored l.e.d. markers in headlight.
- Dash Lights/Display Colors
- Signal Bulbs?
- leveling
- Low Beam/High Beam/Fog
- HID Fog Lamp Kit
- flickers..
- Bimmer Xenon
- upgrading your lights???
- Helpful info please on headlight upgrades!
- aftermarket kits
- Matching light bulbs for clear corners?
- JDM Clear Corners
- Turn signals?
- Lighting help
- Yellow Turn Signals r annoying!........
- clear corners
- Anyone get their corner marker to blink?
- Orange head light turning signal disable?
- Which H4 bulb is the closest match to the Xenons?
- advice needed - clear corners/exhaust/intake
- H4 Bi-xenon conversion kit?
- clear corners
- plasmaglow????
- Technical opinion needed
- HID/Xenon Headlights.. Are they??
- LED front turn signals/parking light
- 6000k bulbs??
- COUPE CLEAR CORNERS on EBAY!!
- G35 HID FOG KIT, ANYONE ELSE SEEN IT? SWEEEEEET
- Auto Head Lamps
- speedmeter light
- Instrument Lights
- Headlight Vibration?
- CATZ HID
- Clear corner for G35 coupe??
- HID Kit: Good Deal?
- Super Plasma Wedge Bulb pics?
- How do I replace clock lamp?
- Dash light dimmer?
- bulb replacements details pleaseee
- Do it yourself Clearcorners?
- Rear lights disassembled
- clearance bulb removal?
- Turn Signal Problem
- HID conversion
- G35 Dual LED Side Markers
- HID bulbs on stock ballast...
- Daytime Running Lights
- How to change the bulb for the Dome Light?
- HID bouncing
- High Beam/Fog light and Clearance Light on Coupe
- Interior/Exterior Lighting Upgrade
- Exterior Lighting Recomendation
- Clear corners on Black
- Gauge Cluster - Lighting
- High Beams/Fog Lights
- running lights
- *Good News* Headlight Haze
- $500 HID Installed
- Will Lighting kit void warranty?
- PIAA xtreme whites
- How do you turn on the parking (clearance) lights?
- Headlight Replacement. How do you get in there?
- Help with install on PIAA Super Whites
- Which lights??
- LEDs or incandescent in the instrument cluster?
- Headlight conversion
- Spoiler Brake Light Question
- Xenon v. Halogen
- Headlights
- Clear Corner
- Bulb question
- G35 head light switch
- XENON headlights
- headlight bulb change
- Fog Light Bulb Upgrade PICs
- Changing Interior Lights
- Where to get XENON kit?
- G35 with Xenon 8000K
- Clear Corners
- Signal lights
- the bi-xenon twist
