- NEED SOME Help!
- horn wont stop honking...
- Just Bought 2004 G35x - Rust Issue
- '06 projectors on '03 G35 coupe (USA model)
- 04 g35 coupe srs aurbag module location?
- Fire damage!!
- Are the Undercarriages of 03-07 coupes, 03-06 sedans all the same??? sedans??
- Rack & Pinion still leaking
- Help: Cipher Tool does not detect ABS
- rough idle at star up..need help please HELP
- cigarette lighters not working (not charging)
- Flushing clutch fluid
- Starter , Alternator HELP
- Rev up and non rev???
- Extended Warranty ?!? PLEASE HELP!! Check Engine light..
- Dome lamps
- Paint chip repair
- out of curiosity....does anyone know
- ECU Not Ready - Setting SRT Flag ? ?
- 2004 coupe GPS problem
- Car starts, then shuts off...
- coolant cap
- G35 smoke coming out of my engine
- 06' stock coupe, auto, athens blue
- My key fob works intermittently....!!!!
- Window Motor Probs
- Help!?!?!?!?!?
- Driver Seat Airbag Problem,( need help)
- Multi point inspection and warentee ?
- Tires for 2006 G35 6MT
- Want to upgrade my OEM Horn. Any recommendation?
- Tachometer Jumps, erratic
- Steering wheel shakes
- Key doesn't unlock doors/battery draining
- security system going off for no reason.
- The VDC,Slip, and Brake indicator lights!
- Alignment specs
- Brake Light Replacement
- Nissan FAST
- Help, bumpy ride
- Anyone have a wire tuck DIY?
- Sunroof
- brake upgrade 06 dual piston
- Regrease n Clean Axle Twice n Click comes right back
- Hello! Lowering Question
- So when our brakes get bad our traction control goes off???
- Can anyone recomend an Infiniti dealer that can sell me an OEM part
- Is my car ok?
- Key not working
- RAS light and SLIP light
- AC won't stay cold
- Cooling Question
- Opinions on yellow coolant
- nismo radiator cap
- Best Anti-theft protection? Ravelco
- ground wire points for trans and ecu?
- multiple error codes
- g35 factory jack unique?
- shaky steering wheel
- Droning noise when driving...
- my civic failed smog...any suggestions?
- Airbag replacement?
- Error codes need some help
- A/C and Audio went dead
- Fx wheels on a g?
- 350z cover on a g35?
- Complete DIY's on starting, charging, engines, trannys, etc.
- Valve Chatter or similar sound from engine
- Sunroof
- help Idler pulley broke!!!!!
- AC turns off at high speed
- Wide or Narrow Band O2 sensors
- Key will not turn
- Is Cyberdefender good? PC Tools?
- Clicking noise when braking
- Steering angle sensor
- Computer diagnostic ('04 sedan)
- Removing gas from the 07 model
- AC is only cool while moving.
- Trying to remove Glue
- Inaccurate Fuel Reading
- Car dies @ higher speeds
- Cold air from AC only works at 60 Degrees
- 350z engine swap into a G35? feedback ASAP
- Just 2 random questions :)
- Strange battery/headlight/interior light problem
- which strut bar is recommended?
- A/C Died in Palm Desert!!!
- Door Lock Broken??
- I-Key issue
- Help! Rev light!!
- Engine Bay Hose Sizes!
- Car smells hot
- I Want to change the Spark Plugs
- Oil Pressure Readings
- FML NEED HELP with my trunk!!!
- 90k service: what can i skip?
- Belt Issue - Any ideas as to what is causing this?
- Has anyone upgraded their horn?
- Interior dome light
