- Oil Question
- Whirring sound totally dependent on speed
- help w/ oil leak
- Need a good shop in SOCAL
- Clutch pedal damper
- Crank pulley replacement problems
- Throttle sticking/hanging
- Replaced Radiator lost trans fluid have question
- new member
- A couple of conerns regarding a light as well as some sound..
- AAM Competition BOO! Halloween Special
- Weird cable disconnected
- p1273 & p1283 - Need tune?
- Replacing Head Gasket after over heat - Planing heads?
- How to replace head gasket?
- CAN Readers?
- Unknown wire hanging near oil filter
- 350z engine in G35 (not HR)
- Help please on my 08 g35x
- Need to remove fuel from gas tank. HELP HELP
- What are the symptoms of BHG?
- Engine trouble
- Oil priming advice needed
- clutch replacement help
- HELP!! Engine Swapped now Car Not Starting (Cranks)
- 2007 infiniti g35x Radiator help
- 2005 G35 Coupe 6MT - STRANGE electrical/starting issue
- broken manual mode 2006 g35 coupe A/T
- Please help. P2128,p2138 04 g35 coupe 6mt
- Engine swap issue
- P1239 Faulty Electric Throttle Control Actuator
- Not sure what's wrong. Doesn't run...
- 2004 Infiniti G35 Sedan Fuel problem?
- G37 motor and G35 transmission
- G35 Sport manual not working all the time
- VQ35DE need opinion on problem
- Oil Leak ON MY 03 G35 SEDAN
- Service Engine Soon light
- Blown head gasket
- Temp rising/AC blowing warm
- Flywheel Bolt Sheared Unexpectedly
- Ac not working? ????? Help!!!
- Need help obd code
- 03 sedan won't rev past 1,200rpm
- Please help with engine!
- I'm a dumbass and now my A/C blows hot
- 2006 6MT will not start - clutch?
- 7 speed transmission
- JWT Clutch/flywheel nightmare
- Motordyne 5/16″ Plenum Spacer- questions
- G35x to RWD ... help
- What's needed for manifold
- Transmission Coolant Problem
- G35x 05 new starter new battery won't start
- Catch Can (with breather) No vacuum an issue?
- Coolant/Antifreeze Mixing Colors - HELP!
- Starting Problems
- Replaced Radiator Fan
- 2003 G35 Sedan Radiator repair info (not DIY)
- Vdc off, slip, and ses lights on
- I think my car is bipolar...
- P1078
- 04 g35 coupe front O2 sensor oem and part number?
- Manual mode in automatic
- Timing chain noise
- Service Engine light question
- Help please!! No start after replacing knock/camshaft position sensors!!
- Getting P1128 code - Throttle Control Motor Circuit Short
- Valve clearance
- 06 6mt coupe misfiring 😓
- Cam installing
- Am i that lean or is it something else
- Vortech s/c what fuel + supporting mods
- how to reach 500HP+ with 5K$ Budget
- 06 AT manual mode problems HELP!
- Which MAF to buy?
- Don't know what to do anymore
- Engine dies on warm start!!!
- Radiator Fans
- Only carbon buildup in 4 cylinders? (pic)
- NEED HELP ASAP Valve Body/Transgo
- Idle Issue. Is the "Stealership" trying to rob me? Please Help!
- vq35de engine stand
- Flywheel Question
- Intermittent high pitch whine, does not change pitch
- plenum spacer or exhaust
- 04 G35 Engine to 03 G35 Car - Issues, please help!
- What is the name of this tube?
- AC Condenser Fan and IPDM
- Greddy twin turbo and crash bar
- Wide band sensor location
- redlining the g
- '04 G35 Coupe Engine Tapping Sound
- Hard shifts
- 03 Sedan E-Fan Conversion
- Idle hunting after disconnecting battery, please help!!
- Leaky fuel damper after wiretuck/fuel mod delete
- Engine Swap - No start (07 6MT Coupe)
- Blown Engine 05 TT
- Need Advice on Engine Build Please!!
