- Code p1273 (weird Symptoms)
- Help Noob
- Transmission swap
- Help. P1084 Code
- Overheating problem
- JWT TT G35 turning off?!
- leaking line
- 350z Spark Plug Tube Seals
- Shifter shaft spins..wtf?
- Rear main seal/upper oil pan rtv leaking :(
- Radiator Cap???
- Turbo Help!
- 2jz/t56 mag swap
- Whining in the engine bay?
- rattling noise from engine bay
- VQ35HR heads on a VQ35DE short block?????
- How to Break In A Remanufactured Engine
- HELP!! ABS making noises when engine is turned off
- Engine harness question PLEASE HELP
- Need help fellas new car new problems!!
- Bad Rumbling and Shifter Off Center
- Need an Air/Fuel Gauge
- APS help
- Question for those of you who've had Camshaft or crank sensor replaced
- VDC & SLIP light on after modding
- First G35X 5AT AWD to 6MT RWD Driveshaft Issue NEED INFO
- Overheating problems?
- Does this sound like a belt issue?
- Engine sound in my new to me car
- A/C compressor????????
- Help please!
- Code P0452 - Now What?
- 2005 G35 Engine Overheating
- 07 G35S AT Accelerates Slowly
- camshaft
- After Changing Spark Plugs- Rev Issues
- random misfire please help
- Engine Blew - What year engine will be equivalent?
- 05 G35 Tranny (no reverse)
- Misfire DTC Code Question
- is the transmission oil fluid matic s okay for 03 coupe
- i need help cleaning throttle body
- Dead Cylinder. $13k engine replacement
- waterproof?
- Check Engine Light after Car Wash
- need help with hesitating g35...
- starting issue
- AT Fluid leaking and smoke/steam coming from right side of engine.
- Clutch kit
- limited slip diff
- Bad thermostat? coolant leaked from reservoir?
- I changed my air filter...now i have a problem
- 06 auto g35 engine into 03 6 speed g35
- No start - weak spark?
- P0705 Transmission issues
- 2005 G35 Transmission
- V8 swap passing emissions thread
- Valves Covers Wich Route ?
- Time for New Valve Covers?
- Oil catch can solved one problem, created another.
- automatic tranny rebuild
- Radiator Leak?
- P0158 engine code thrown!?!
- Did have CEL - PO340, fixed that, but still slow to crank..???
- 1400 hp Wankel engine.....I want one!!!
- need help asap with blown motor
- cranks but will not start
- g35 backfiring ?
- Hey, Y'all who wants some spark plugs?
- Replacing 2003 G35 Coupe Engine and Tranmission. Need Help Matching Parts
- Vq35de
- 2004 G35 Startup clanking noise
- Help blew my motor looking for correct replacement
- Radiator replacement - cannot attach fan shroud
- Transmission problems?? Car stalls, dies while driving, not cam/crank sensor
- G35 Pulleys for the serpentine and fan belts
- whats the weak link?
- Help please: Transmission fluid
- Pistons and Rods
- slave cylinder
- Opinion needed fuel return
- Rough start after car sits :(
- Looking at buying a oil catch can
- Sucked water through turbo
- Need some info on my aftermarket clutch.
- Few issues with my 03 5AT, Possible upgrades?
- Need help with misfires. P0300 and P0304...
- Oil Leak - Back pass the oil pan
- Clicking Noise at 3k-6k RPMS (With Video)
- Need Help!
- Bank 1 and Bank 2 Camshaft Position Sensors identical? 2005 Sedan 6mt
- Very high RPMs at 65-80 A/T
- Trouble After Upstream O2 Sensor Change
- UR pulley set worth it?
- timing chain kits?
- g35 clicking noise when accelerating
- Any "Limited Slip Diff" Guru here ??
- Kg/Lb Reduced G35
- Engine quits unexpectedly
- Trouble with Mishimoto radiator install
