- Current Owners Advice
- serpentine belt conversion
- No spark and No check engine light?
- 03 vs. 06 Fuel system
- Exhaust ticking sound
- 2003 sedan not starting
- Upgrade stock motor or engine swap
- LOUD rear axle clunking sound!!!! [VIDEO]
- Motor Mounts
- Overheating hellllllp
- Strong plastic smell now limp mode.. Help!!
- Fact: Black painted intercoolers cool better than shiny chrome one
- Top speed Y-pipe fitment issues
- Clutch Pedal not regaining pressure(Trouble with Bleeding)
- g35 issue attempting first time engine removal
- SLIP, VDC off, SES lights
- 04 Sedan G35 - Couple of Qs! (Loud engine ticking + Horrible shifts.) Vids included!
- Engine Bay Harness
- oil spark plugs
- Help with ses code p1078
- I need pictures! (Diagrams)
- Motor swap 350z vq35 to g35 vq35
- 2004 G35 Coupe A/C Idler Pulley
- Crank pulley removal 2006 AT
- 6th gear stuttering
- unknown bracket. Help identifying
- Radiator to fit Nissan Skyline 350GT
- Please Help!! P1283 & P0158 Codes
- What part of the exhaust is this(pic inside)
- Don't know what to do: p0021 & p0300 codes!
- How to get an engine overheating alarm before engine actually overheats
- Please help crazy issue
- Help with Engine Check Light beeping when I start car
- A/C belt problem
- 03 G35 Sedan: Overheating... Coolant Level is Fine, Reservoir Full
- Help to diagnose weird Data logging data - Bad O2 Sensor(s)?
- Evaporative Emission Control System Leak (P0455)
- Low rpm after plenum spacer install
- Service engine soon light comes on occassionally.
- Frustration35 is what they should have named it
- Hose sizes
- Osiris revup tune + P0345 Code =All Bad. PLEASE HELP
- Can I get help identifying this part?
- clutch issues
- Identify this part - next to intake
- 2003 G35 issues
- How much is the average cost for valve cover gaskets?
- Engine Hesitation
- 2005 G35 Coupe 5AT Engine Knock
- RPM drop during cold start.
- Smell Oil Burning
- 2006 G35x exhaust tips
- car sounds like its about to explode
- ANOTHER p0011/p0021 Post..
- 2003 G35 Sedan - Cranks but Doesn't Start
- Need some specs
- Motor swap, security immobilizer
- HELP! Random loss of power 04 5AT
- Vq25det info
- Procharger C2 compatibility
- What's this noise?!?!
- Help! Location of AWD transfer case control module
- Torque Converter not unlocking
- CEL after header install.
- New Engine Install
- 04 Coupe 6MT Motordyne TDX V2 & ART Pipes Install HELP
- 2004/2004.5 Service Manual
- Sprint Booster for G35X maybe obtainable?!?
- Oil Additives
- Low idle. Normal?
- Help me please!!!
- Engine sensor and ses light help
- Options for Oil Consumption fix for those that out of warranty
- Test pipes question
- VK45 swap easier than a VK56?
- 03 G35 5AT Transmisson problem
- LiquiMoly Ceratec-Worth it?
- Tuning software
- differences between vq35de
- G35 coupe
- Fluid
- Burning smell and smoke: Oil leak onto headers?
- Engine lift how to?
- G35 Rear Knocking noise HELP!!!!
- Oil in exhaust-Turbo or headgasket
- Figuring out how much horsepower i have.
- HKS DLI II harness or pinout
- car stalls while decelerating
- seeking your advice on 2005 G35 5AT differential swap
- 2003 coupe snapped camshaft! and more need advice.
- Is my ecu done?
- Help! project car will not start .or idle
- 05 g35x tranny question
- I need help with these codes!
- Another NWP 75mm TB review!!
- Engine swap problem
- Help! Problems with shifter
- Which is better???
- Replacing rod bearings on 05 G35 6MT without pulling engine
- Nengun
