- Is it my clutch or somethin else???
- Another newb ?
- Engine rebuild advice
- Fuel Pump keeps burning out HELP!!!
- HELP!! Leaking coolant and cant find the problem!!
- emanage
- No heat at idle help!!!!
- engine rev up during driving?
- Naturally Aspirated 03 coupe??? advice
- TC-W3 marine two stroke oil as a gasoline additive
- Engine Rebuild advise
- Idk
- issue after taking my car to a mechanic
- Can't shift gears! Please help
- Blew my motor, need new one, advice please
- new engine needed
- NWP75mm throttle body 15hp- Still not convinced
- Valve Covers
- Engine hesitation at low load-possible fix
- Spark Plugs
- MyCarFax
- Interesting Tool - Lubricheck
- To change transmission fluid or not to change, that is the question
- Symptoms of bad crank sensor
- Fuel Injector Size [See Pic]
- Codes p0102, p0113, p0223, p0123, p2135, all TPS related what do I do?
- Car dies while on freeway. Any advice?
- HUGE loss of power and LOUD sucking noise NO ENGINE CODES
- ABS, SLIP and DFC Off Lights on + Limp Mode Problem
- crappy mpg with high octane
- New & Current info for Transmission Fluids and Differential Oils for G35x 2006
- Strange Piston Difference
- What is the best balance between drifting and high speed cornering (diff question)
- Has anyone ever corrected a P0011 and P0021 error code?
- Engine knocking...
- Skilled Tuner Question?
- 'tire maintenance' light...
- Recommendations for Service 2004 6MT
- HR Cams and heads on a VQ
- Cheap valve cover??
- Basic N/A Engine Rebuild
- Boost Loss, PLEASE HELP!!!!
- Weird Thing Happened
- how to replace serpentine belt??
- Coolant Drain question
- Reflash service on ebay
- Any difference from AT / MT Throttle Body?
- Will Megan Racing Midpipe fit with HKS Axleback Exhaust on G35 sedan?
- Oil in bank 6
- Non rev up plenum
- DIY Drive Belt Replacement (Serpentine Belts)
- !!New g35 driver- chip advice!!
- 03 g35 weird cam position sensor problem
- I think I found the grommets used by R+D for valve covers
- My G35
- 2007 Cat exhaust front support bracket fit 2005?
- Changing Spark Plugs
- issue after doing full maintenance
- HELP! Car will not start.
- new g35 driver ses p1084 helppp
- JWT Clutch and Flywheel - No chatter??
- Best way to operate N/A with Vortech?
- If you replace your heater hose
- 04 g35 coupe wont start
- Hard start and weak power, No Codes
- Radiator Leak or is this a hose?
- Car sounds terrible at idle.
- INSANE horsepower
- Quietest HFC/test pipe options for supercharged G coupe with Motordyne exhaust?
- Flywheel Torque Specs?
- 350z rev-up to G35 non rev-up engine swap
- How do i know if i need a ECU tune?
- Help Engine Sputters than stalls.
- Part number for air relief plug
- Removing PS pulley
- Vortech or built internals???
- Injectors on NA build
- 2nd engine rebuild: now will not start? Help!
- Light belt squeal after rain
- How to amplify stock exhaust sound
- G35 hard to start when cold
- Exhaust dripping water for fuel?
- Paddle Shifters? 04 Coupe
- My impressions of the NWP 75mm Throttle Body Kit
- 2004 6MT part number
- SES P0011 & P0021 and Tapping Noise! Please help
- SES light but supposedly no code??
- Help...Aeromotive 340 fuel pump install
- Over heating!!
- NWP Big Bore 75mm Throttle Body Kit Review
- g is shutting off while driving
- Changing Clutch with stock Flywheel
- Engine Reassembled - Misfire But Sets No Codes??
- Help! What's this bolt hole near Plug #6?
- After Water Pump, Slip, VDC Off, Service Engine Soon
- DIY Body Control Module Replacment ( BCM )
- Must drain my gas help!!!!!!!!!!!
- stumbling issue
- Car won't start anymore 2003 6mt
- Ignition Coil burning
