- Swirl control valve - error code p1130
- Test for cam and crank sensors
- Mizu Radiator Experience.
- How to clean throttle body (no relearn procedure) ???
- New Here!! Need Help! Engine won't start! Runs rough with low rpm
- Opinions on Best Place To Purchase Used Motor?
- 75mm NWP throttle body is in
- Supercharged 2007 G35 Sport Sedan. Maybe a bad tuning?
- Mods to do
- Fuel Economy
- 3200 RPMs at 80MPH?
- Fuel Pump Rubber Gasket
- Car struggles to Start / High-idle: Please Assist
- Sticking Clutch
- 02,g35 downshifting randomly
- Need some opinions on rattling sound from cylinders
- CJM stage 3 rev A installation
- 03 G35 no power to solenoid
- Mid pipe replacement?? Dealer or muffler place???
- 04 g35x engine change
- Just Wondering
- G35 transmission question
- G35 Radiator Fans turn on after 5-6 miles
- Different Injector o-rings on rail side and plenum side
- Running Rich, Knocking, No CEL's! Help Please!
- Are one of my sensors bad?
- Clicking sound
- Replacing ECU after engine swap
- Is the Vin on Chasis on the Engine Long block?
- Can I put a 2006 G35x Sedan engine in to my 2003 G35 Coupe?
- In Depth Review of the NWP Engineering 75mm Big Bore Throttle Body Kit
- Weigh in
- G35x 2006 spark plug oil leak question ??
- PO340 Code
- Really weird trouble with my g35 03 sedan
- electrical connector replacement: valve timing control solenoid connector
- My N/A Revup NWP 75mm Throttle Body Review
- VDC switch problem
- Need advice on built engine break-in and tune (unique situation)?
- B2S2 O2 Sensor faulty Code P057
- G35 Choking
- 2004 sedan engine swap
- Question!! Camshaft, Valve Spring and Valve upgrade!!!
- NWP 75mm throttle body review
- LSx Swap help
- Newbie, ABS,Slip,VDC lights- searched and still need help please
- G35 coupe engine swap
- AAM or CJM fuel return system and what stage?
- strange thumping/ticking sound at idle when warmed up...
- 03 G35 Sedan overheating!
- 6MT HR Hesitates at 1000 RPM
- Vortech V-2 or V-3 Si Trim?
- Car runs sluggish after oil cooler install.
- service engine soon light
- 180 LBS In 5 Cylinders & 0 in #4 - Is It Scrap Metal Now?
- Cam shaft sensor problems
- Need quick help about engine install.
- Watch Out: Infiniti Spark Plug Replacement at Dealerships
- AEM Wideband Failsafe gauge?
- horrible noise please helppp
- Oil Consumption..Synthetic Oil
- Weird Oil Consumption
- Horrible gas mileage after ECU reset
- Need help on starting to mod
- 04 G35 overheating
- clutch getting "stuck"
- adding a flat fan to the ac condensor
- Supercharger build? Injectors, Fuel Return ARP L19, retune?
- Engine ticking noise...
- Need New Clutch
- Tanabe Exhaust causing Heavy Vibration!?
- Overheating... Don't understand why...?
- What else to do when while my car is on the lift?
- 2004 g35 sedan overheating
- Car wash + CAI.. Safe?
- Injen filter help
- Clear Self-Learning ? P1273
- need help for a full exhaust set-up?
- Noise Shifting
- Replace rev up engine with non rev?
- HELP. Headers for powerlab gt35r turbo kit
- Motor wont hand crank
- please help. Fuel return line size and length?
- Idler pulley and AC pulley question
- Charge Issue(E Brake and Charge Lights on)
- New driveshaft installation????
- Squeaky noise when shifting.
- How loud is a vortech for daily driving?
- shaking/jumping when idling
- Shifting issues after new clutch & pressure plate
- Power Steering Leak
- Please help......
- [VIDEO]--Engine Kock
- 2003 g35 coupe flex pipe size?
- Purolator Synthetic Oil Filter
- 2008 G35 AWD VQ35HR Engine Rebuild HELP!!!
- knocking noise coming from compressor area
- Engine clicking noise - Possible lifter issue
- KOYO V-core radiator & Vortech plumbing?
- Knocking
